Difference in dash board screen
shahedz Nov 3, 2012
  1. shahedz
    shahedz Member
    Hi eveveryone
    i was looking at some of a4s here and I noticed that he screen in between the rev and speedo on some a4s are fully red dot matrix and some are red and white.
    was this an option? As some from 2006 have red and white yet some from 2008 are all red?
    thanks
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    The full colour DIS wasn't an option that you could choose separately, it came as part of the spec of certain models (e.g. in the UK the S4 has the full colour DIS), and if you ordered the sat nav (RNS-E) then you got the full colour DIS (the red DIS has a firmware bug that means it doesn't automatically display the navigation information when you set a route active).
  3. shahedz
    shahedz Member
    Thanks for clearing that up Petroldave, is it full colour ? Or just red and white?
    thanks
  4. PetrolDave
    1,559
    85
    Full colour - shows red, green, blue and white.
  5. Rastamouse
    Rastamouse Welsh Audi Nut
    398
    19
    Can this be retrofitted by any chance?
  6. shahedz
    shahedz Member
    Brilliant , that sounds great,
    Thanks for replying
  7. hades-
    9,482
    646
    it can if you can find 1
  8. Rastamouse
    398
    19
    I take it that they are quite rare then? And do you know if they are just plug n play or will they have to be coded
  9. hades-
    9,482
    646
    not plug an play
    needs codeing for immo etc
  10. PetrolDave
    1,559
    85
    You have to fit a complete new instrument cluser, not just the DIS display - hence the need for immo recoding etc.
  11. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    Just throwing it out there so sorry if I've got the thing wrong but I've never actually seen the circuit board of the instrument cluster but is it not possible to swap the screens over ie unsolder one and solder a new colour one on ?
    Sorry if its a stupid idea just thought I would ask. I know there's a thread on here where someone has re-soldered new LEDs onto the circuit board to change colour
  12. hades-
    9,482
    646
    when i had my 1st colour fitted
    i asked this and the answer was always no
    but it could be worth a try if you can get the screen
  13. Wrath
    Wrath Well-Known Member
    1,196
    42
    I believe the circuit board is very different.
  14. NHN
    29,576
    1,779
    It wont work imho, if you think about it more, the signals to make a pixel change colour, it wouldnt work as there would be no signals on a red dis cluster to change colours.
  15. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    I have the full colour DIS in my car and it isn't an S4...unless it has been retrofitted in the past?
  16. PetrolDave
    1,559
    85
    As I said in my original post - "it came as part of the spec of certain models", by which I meant spec levels like S-line etc. not just S4.
  17. NHN
    29,576
    1,779
    He did say "eg" referencing S4, wasnt model specific, did your car come with RNS from factory?
  18. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Yea sorry you're right, I stand corrected. :keule:
    Yes did come with RNS from factory. I believe it has most of the options on my model aside from parking sensors, storage pack and the fridge thing in the glovebox.
  19. NHN
    29,576
    1,779
    There's your answer then :)
  20. PetrolDave
    1,559
    85
    As I said....
