difference between sport springs and standard
jbh Jun 30, 2013
  1. jbh
    jbh TDi lover
    1,412
    164
    how much lower is the sport over the standard A4 ?
  2. griswold
    griswold Member
    350
    Think factory is 20mm? I've just fitted eibach springs they say 30mm and apex do 40mm springs
    I parked next to a standard A4 and it look jacked up compared to mine.
  3. jbh
    jbh TDi lover
    1,412
    164
    I was thinking 20mm but wasnt sure. ive just picked up a set of sport avant springs so thinking on getting these put on and doing away with the coilovers.
    in an ideal world I would like the eibach 30mm springs but just spent a fair wad on the wifes sharan and getting the A4 through its mot
    any pictures of youre car with the eibachs on it?
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    Its something like 20-30mm lower.
    I fitted a 40mm kit to mine and it dropped it by about 10mm
    Could do with another 10mm I think though,
  5. jbh
    jbh TDi lover
    1,412
    164
    any pictures of before and after Scott?
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    The sports setup - PR code 1BE is 20mm lower than the standard setup - 1BA.
    #21 shows the difference between 1BE and 1BT (7mm higher than standard) to give you an idea
  7. dubster67
    dubster67 Member
    152
    9
    according to etka 1BV, which is TQS, is 30mm lower.
  8. ScottD3
    15,161
    1,122
    I tried looking for a good before and after pic and I can't.
    Loads of afters but none before.
    Here's is a after pick for 40mm lower.
  9. jbh
    jbh TDi lover
    1,412
    164
    looks good Scott. what size of wheels is that you're running on?
  10. ScottD3
    15,161
    1,122
    18x8j with 225/40/18
  11. jbh
    jbh TDi lover
    1,412
    164
    It suits them. ive got the 17x7.5j to go onto to mine im thinking on 225/45/17 tyres for them
  12. aragorn
    18,380
    831
    I'm not sure switching to sport springs is really worth the effort involved. Stock sports sit far too high, and look silly with bigger wheels on.
    225 45r17 is the correct tyre size for 17's on a B5.
  13. Mr K
    Mr K Member
    335
    Stock sport and TQS's all seem to sit with the nose in the air. Not sure if this is a result of the rear springs sagging, or just how audi built them.
    I'd order up some H&R's or Eibachs.
  14. jbh
    jbh TDi lover
    1,412
    164
    the 17" wheels ive got came with 235/45/17 on them and after a phone call today it looks like thats what will be staying on them as I have 4 nearly new heading my direction for a good price
  15. Mr K
    Mr K Member
    335
    Do SE, Sport, and TQS share the same shocks? They need to match the springing.
    My TQS seems very stiffly sprung - Id say its similar to my old S8, which was similar to my 2.8 A4 with H&R springs and sport shocks (which couldnt keep up with the springs)
  16. jbh
    jbh TDi lover
    1,412
    164
    the quattro has a completely different suspension set up on the rear so the springs and shockies are not interchangeable with the 2wd to the quattro
    im pretty sure the fronts are the same just depends on spec and engine.
  17. Mr K
    Mr K Member
    335
    Yup, but I thought both 2wd and 4wd where available in SE and Sport. Ive had a 1.9TDi 2wd with sport suspension, a 2.8 Quattro with sport, and later sport shocks and H&R springs, and a still have a TQS. Obviously the TQS is only available in quattro.
    Also worth noting, Sports have a 'quicker' steering rack and different ARB's. 2wd cars have no rear ARB except that built into the beam axle.
  18. aragorn
    18,380
    831
    I've heard that "sports have a quicker rack" thing before, but its not backed up by ETKA. ETKA only lists racks by engine type.
    TQS has an S4 rack. Other than that, they're split 4cyl / 6cyl.
  19. jbh
    jbh TDi lover
    1,412
    164
    well it looks like ill be fitting a set of eibach 30mm lowering springs.. Ive just won a set of eBay for much cheapness :rock:
