Difference Between K04's ??
motfree Sep 21, 2010
  1. motfree
    motfree Member
    464
    hi there just been speaking to an Audi specialist regarding my turbo .. apparently mine is a k04-020 and from my research i know there's a k04-022 and k04-023 available ...
    will either of these fit onto my car ? its a 1999 s3 .. as i have found a k04-023 for £200 just had seals done with new feeds on ..
    cheers
  2. tompearson
    tompearson It's all in bits
    219
    K04-023 has a hole for an egt sensor which the early S3's don't have. I would assume you could blank this if you wanted though.
  3. motfree
    motfree Member
    464
    Hmmm not sure haha don't want to fork out and find out can't use it .. So turbos are all the same ?
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    the K04-001 is different, but the turbo is pretty much identical with regard to the 022 and the 023 IIRC. Just the EGT probe.
  5. motfree
    motfree Member
    464
    Ordered a k04-023 as aparently the difference with that to the k04-020 is just an exhaust temp gauge which can be blanked off and a bargin at £180 :) just had seals done too ;-)
