difference between Haldex Oil and Diff Oil
V.I.P_UAE Feb 19, 2009
  1. V.I.P_UAE
    V.I.P_UAE Member
    117
    I wasnt aware that the haldex and the diff oil are different?? Just told the garage to change the diff oil thinking it was Haldex?? whats the difference?
  2. Dennis Moeller
    Dennis Moeller Member
    444
    To my understanding there's no difference...it's the same oil as used for the gearbox.
  3. <tuffty/>
    21,235
    3,877
    Isn't haldex oil a hydraulic oil? Gearbox oil is much thicker. I thought the haldex is effectively a hydraulic clutch that engages drive to the rear diff. I suspect the rear diff oil is the same as the gearbox.
  4. Dennis Moeller
    444
    Yes, you're absolutely right! Diff and gearbox are the same...Haldex are different...Sorry for that
  5. <tuffty/>
    21,235
    3,877
    Just ran out to the shed to check the tube of haldex oil I got for its next change in 4k time... defo not gear oil.... far too runny...
  6. V.I.P_UAE
    V.I.P_UAE Member
    117
    Thanks for the replys. Sorry to sound stupid, but where does the Haldex oil go. My car is in the local garage here and I asked him to change the haldex oil and he didnt have a clue, thought I meant Diff oil so he changed that.
  7. Dani_B19
    9,293
    384
    Just do a search and youll find a how to guide that shows you where everything is and how todo, im geussing if he doesnt know where it is to change he isnt going to have the tool in which to change it!
  8. <tuffty/>
    21,235
    3,877
    If he doesn't know what or where a haldex is then should he be doing it at all??
    The haldex oil (every 20k miles) and filter (40k miles) need to be changed I suspect, the haldex has to be warm to aid draining of the old oil (quick run round the block). The new oil comes in a container like bathroom sealant and needs to be 'injected' from under the car, the filter needs a special tool as its bloodu awkward and can't really be done without it.
  9. Dani_B19
    9,293
    384
    Yeah its easy enough todo its just a matter of space, idealy if you have a pit or a car lift then its straight forward but if not it, its a case of useing ramps or car stands to raise the rear up enough to get under. I think someone also used a pair of grips to get the filter off :laugh:
    Also alot of people like to change the filter at 20k, it costs hardly anything for the filter (Think it cost be about £32 for both)
    Hope that helps :icon_thumright:
  10. S3-Oski
    S3-Oski Member
    484
    :uhm:Sorry to hijack but, does any1 know what oil is used for the rear diff? and is there a guide?
    As i rand Audi Chelmsford a few days ago he said there was no oil for the rear diff just the Haldex:uhm:,Cheers Oski
  11. V.I.P_UAE
    V.I.P_UAE Member
    117
    where do i drain it from??
  12. Dani_B19
    9,293
    384
    Theres a 7mm allen key thread where you drain it from. Cant quite rember its exact location.
