Difference between drive select / damper specification
Tom75 Aug 27, 2013
  1. Tom75
    Tom75 Member
    92
    14
    Hi all,
    have a friend who is also planning to order an A3 1.8 TFSI and out of interest I would like to know what actually the difference is between the different drive select / damper specifications that are available:
    [TABLE="width: 589"]
    [TR]
    [TD]2H0[/TD]
    [TD]Without "drive select"[/TD]
    [/TR]
    [TR]
    [TD]2H1[/TD]
    [TD]"drive select"[/TD]
    [/TR]
    [TR]
    [TD]2H2[/TD]
    [TD]Controlled shock absorption magnetic ride[/TD]
    [/TR]
    [TR]
    [TD]2H3[/TD]
    [TD]Controlled shock absorption magnetic ride (sports)[/TD]
    [/TR]
    [TR]
    [TD]2H4[/TD]
    [TD]Driving profile selection and hydr. damper control[/TD]
    [/TR]
    [TR]
    [TD]2H5[/TD]
    [TD]Driving profile selection and conventional shock absorber[/TD]
    [/TR]
    [TR]
    [TD]2H6[/TD]
    [/TR]
    [TR]
    [TD]2H7[/TD]
    [TD]Drive select and magn. damper
    [/TD]
    [/TR]
    [/TABLE]
    For example if you have only "drive select" without magnetic bumpers / magnetic ride how does this affect what you can control etc.
    Or what is for example the difference between "Drive select and magn. damper" and "Controlled shock absorption magnetic ride". Is the first option a magnetic damper but without magnetic ride?
    Regards,
    Tom
  2. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,690
    528
    Where did you find all those options? The only ones listed in the UK brochure are 2H6 (Drive Select) and 2H7 which adds Audi Magnetic Ride.
  3. snakehips
    snakehips Well-Known Member
    735
    262
    As far as I am aware, drive select only affects throttle and steering.
  4. RossR
    RossR Active Member
    501
    122
    43
    It affects quite a few things, but I think the rest are all optional extras (except for climate control). One of the optional extras it will affect is magnetic ride. If you don't have magnetic ride it doesn't affect suspension.
    That's my understanding anyway. No idea what all those option codes are.
  5. Tom75
    Tom75 Member
    92
    14
    Yes, it affects different things.
    These options are taken from an excel file which includes all the possible options but I don´t know where my friend got it from.
    I have for example this [TABLE="class: cms_table, width: 589"]
    [TR]
    [TD]2H7[/TD]
    [/TD]
    [/TR]
    [/TABLE]
    and it would be interesting to know what the difference is compared to the other options with magnetic dampers.
    My friend came up with this list in the first place because he is thinking about what to order.
    Regards,
    tom
  6. Daveotto
    Daveotto Moderator Staff Member Moderator Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,975
    4,372
    Are all of these codes really customer selectable options or just internal codes for the internal workings of the car which need to be set depending on the couple of options you can choose and the level of trim you have selected?
  7. mjcourtney
    1,690
    528
    I suspect you're right. For example: If you ordered a Sport suspension with Drive Select (2H6) and Magnetic Ride (2H7) then I think the factory would add "2H3 Controlled shock absorption magnetic ride (sports)" in the background. Equally if you didn't specify magentic ride they would add "2H5 Driving profile selection and conventional shock absorber".
    The only user selectable options that I can see are 2H6 and 2H7, and unless you're advised by your dealer I wouldn't worry about the others.
    Tom75 likes this.
