Difference between 2 Ohms and 4 Ohms?
sharma May 3, 2007
  1. sharma
    sharma Member
    78
    4 by 100W / 50W RMS at 4 ohms
    4 by 140W / 70W RMS at 2 ohms
    An amp i am looking at has these settings. Whats the difference between 4 ohms and 2 ohms? Can only certain speakers run in 2 ohms? And why does the power increase in 2 ohms?
  2. icenutter
    icenutter Member
    596
    The ohms refers to the impedance of the speakers which is the 'AC version of resistance'. The less impedance the easier it is for the amp, so it can produce more power. This also means that the amp gets hotter, and if it was badly designed or installed, could over-heat.
    Incidentally some amps don't like being run with speakers of too low a impedance.
  3. AndyMac
    9,832
    46
    Ohms is the impedance i.e. the electrical resistance the speaker presents to the amp.
    The easiest explanation is:
    imagine connecting a jump lead across the amps speaker outputs. The impedance of the jump lead is zero ohms (a short circuit), so you would get a huge current through the lead but obviously for a very small time and the amp would self destruct or shut down to protect itself.
    Now imagine a speaker across the same terminals. It has a very slight electrical resistance to restrict the current flow & prevent the amp from shutting down. This is the impedance of the speaker, and simply put the lower the impedance the more power the speaker will suck from the amp. However the amp has to be able to handle this additional current which is why you get some amps that are specifie as 2 ohm stable or even 1 ohm stable. i.e. they have been designed to produce more power if the speaker is low impedance.
    All amps will run at 4 ohms which is the standard for car audio, but some can run at 2 ohms or even less. Subs are available in all sorts of configurations but you need to check that:
    1. The amp is stable at the desired impedance
    2. The amp is still stable at 2ohms when bridged
    If the spec only lists power values per channel at 2ohms and doesn't list a power when bridged at 2 ohms then you can't use it bridged at 2 ohms.
  4. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    andy is spot on
    the only thing i can add is
    some amps specify 2 ohms bridged
    some amps specify 2 ohms stereo (but are not capable of bridging)
    make sure the amplifier you are thinking of buying is capable of doing whatever you wish
  5. sharma
    sharma Member
    78
    So am i right in saying that my amp will automatically detect whether or not the sub/speakers are capable of 2 ohms or 4 ohms and output the power accordingly?
  6. AndyMac
    9,832
    46
    It will but with some you have a switch you need to flick for "low impedance"
