diff oil seals...
rossbrownlee Mar 17, 2011
  1. rossbrownlee
    rossbrownlee Ross_S4
    719
    Hello all,
    Does anyone here have the VAG tool 2062 the drift for installing the rear diff oil seals?
    If so would it be possible to get a drawing with the accurate dimensions marked up? I am hoping to turn one at work if I can get the sizes.
    Cheers.
    Ross.
  2. aragorn
    18,600
    870
    I tapped mine in with a socket and big screwdriver.
  3. jcb
    jcb Active Member
    4,132
    13
    just use the old seal after you pull it out!....its made for the job!
    do a search on a rear suspension rebuild and I described doing mine
  4. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    If your turning something at work to fit it just make at a few thou smaller than the new seal you have to fit. Bobs your uncle. I just used the old seal myself.
  5. rossbrownlee
    719
    Cheers.
    ian52 - I don't have the new seals to get the sizes.
