Diff fill plug stuck!!!
ian52 Feb 9, 2010
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Well its well and trully stuck. Rounded off inside it was that tight and gave it a go with a hammer and puch to get it started but no joy. Is there any other way to get oil in like by pulling the drive shaft out?
  2. aragorn
    18,299
    804
    if you've got a MIG, stick a close fitting bolt in the hole, thread end first, and blast it with the welder.
    The heat will break off the corrosion and it'll just wind out.
    If its rounded off thats the only way your going to shift it.
  3. Broken Byzan
    13,237
    465
    I suppose you could fill it the same way they do with haldex diffs and fill through the drain hole and swap the plug in sharpish
  4. adamss24
    adamss24 Well-Known Member
    4,584
    405
    On top of the diff there is a breather covered with a rubber bung. You can fill it trough that if you can reach and have a small probe wich will get trough the hole.
  5. ian52
    1,199
    I might try a big easy out as the hole must be about 10mm deep so ill see if there is any at work that fit. I had thought about welding a bolt or nut on but that means going to a garage. I need to do the oil seals anyway and a wheel bearing so i might just fill it that way,im sure you will be able to do it that way. I wasnt going to bother with the seals for a while but looks like i might have too now.
  6. hardhitter
    hardhitter Member
    138
    What size hex key is the plug ?
  7. aragorn
    18,299
    804
    easyouts arent really designed for shifting really badly siezed things like that, and all that will end up happening is the easyout will snap.
    I'd take it to a garage and get the welder onto it, because otherwise all you'll end up doing is making it worse.
