Diesel & tyre wear
Discussion in 'A3/S3/Sportback (8P Chassis)' started by stewarta13wsb, Oct 29, 2006.
  1. stewarta13wsb
    stewarta13wsb Member
    Feb 23, 2006
    139
    Sorry if this is a really stupid question (and I may have picked up a comment in another thread totally wrong) but does having the 2.0TDi have any impact on tyre wear - i.e not engine size but diesel rather than petrol?? :redface: :redface:
  2. Advert Guest Advertisement
  3. Randomjim
    Randomjim Active Member
    Aug 18, 2006
    2,752
    Diesel a heavier engine :ermm:
  4. marriedblonde
    marriedblonde Moderator
    Dec 6, 2004
    4,371
    I'm assuming all torque being delivered in a big lump doesn't help tyre wear.
  5. stewarta13wsb
    Feb 23, 2006
    139
    Heavy enough to make a difference then?? Sorry to be thick but this is my first diesel and I really don't know that much about them... but then you've all guessed that already :yes:
  6. Randomjim
    Aug 18, 2006
    2,752
    I dunno was kind of a guess to be honest
  7. benw123
    benw123 Moderator
    Oct 10, 2004
    1,863
    All the answers are already in this thread: the heavier engine means more tyre wear because of the extra weight the tyres have to support, especially when subject to cornering and braking forces.
    And, as MB says, the extra torque usually means more wheelspin. Even with ESP switched on, a certain amount of slip is allowed which obviously increases wear.
    However, the truth is that your driving style is the biggest influence on tyre wear. Obvious as it sounds, if you drive everywhere gently, your tyres will last longer.
  8. Randomjim
    Aug 18, 2006
    2,752
    And what tyres you have
  9. benw123
    benw123 Moderator
    Oct 10, 2004
    1,863
    Yep - also true!
  10. marriedblonde
    Dec 6, 2004
    4,371
    I started out with the Rosso's which where not too bad at all in the dry but pants in the wet IMHO. Replaced these with F1's as good if not better in the dry, excellant in the wet. Nice and progressive, as quiet and they wear much, much better! The last lot on the fronts lasted around 19-20K
    J.
  11. Randomjim
    Aug 18, 2006
    2,752
    Goodyears? might have to try them
  12. benw123
    benw123 Moderator
    Oct 10, 2004
    1,863
    Yeah the F1s are highly rated. I've got Pirelli P6000s on mine which drive well but drone at high speeds. Before that, on my old 16s, I had Bridgestone Poteza RE040 which was also good - hard wearing but with good handling.
  13. marriedblonde
    Dec 6, 2004
    4,371
    Yep the good years! Excellent tyres :)
