Diesel Tuning Box
Anthony566 Feb 17, 2014
  1. ABYSS
    ABYSS Andrew - Diesel Tuning UK Site Sponsor Black Edition S3 Saloon Team Ara Blue
    940
    524
    93
    Wow that's fantastic Tom :)
  2. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Once these are done Andrew I will do an install wright up and also so day in the life of numbers with my box.
  3. ABYSS
    940
    524
    93
    Great, give me a few weeks and I'll organise getting it onto the dyno at motoscope :)
  4. Anthony566
    732
    111
    43
    Sounds like a plan :)
  5. rabhrab
    rabhrab Member
    134
    24
    Not complaining Andrew......... just the opposite, am very pleased!
    I got this from you in January this year and have been running it on your factory set map since fitting it. I was thinking about now trying a different map. What do you suggest as my next step?
  6. ABYSS
    940
    524
    93
    Bob I'm sure he's running map 4 plus 2 or 3..
    If you've not adjusted it that's like having a gorgeous blonde with mahoosive boobs and not touching her ....
    Give us a call and well talk you through it :)
  7. rabhrab
    rabhrab Member
    134
    24
    I've just gone and set it to map 4+2 and will try it tomorrow. Will give you a call if I have any difficulties.
    Thanks.
  8. BigGreg
    BigGreg Active Member
    121
    32
  9. ABYSS
    940
    524
    93
    First of all we actually provide dyno figures to back up our claims, and our systems are of a higher quality.
    ill be up front and send you to the manufacturer of our kits. Chiptuning von DTE-Systems: Leistungsoptimierung mit Klasse - Chiptuning DTE id suggest you ask our competitors who are actually manufacturing their kits as a lot are buying cheap kits from europe and adding a massive mark up on them.
  10. BigGreg
    121
    32
    I will have a read thanks.
  11. ABYSS
    940
    524
    93
  12. BigGreg
    121
    32
    How do I work out what one I need? It's a 2.0Tdi 170 dpf Oct 2008
  13. Anthony566
    732
    111
    43
    BigGreg likes this.
  14. ABYSS
    940
    524
    93
    The link I sent above is for your car Greg
    2.0 170ps upto 220/225bhp
    BigGreg likes this.
  15. BigGreg
    121
    32
    That will be a sale then. Thanks a lot for your help, very professional.
  16. BigGreg
    121
    32
    That's me all over. Why have standard if you can improve it. ;-)
    One day you might get to see my previous rides.
  17. Anthony566
    732
    111
    43
    Im pulling your leg Greg :) I havr had my box for a few weeks now and love it ...
  18. BigGreg
    121
    32
    So what made you choose DTUK over TDi Tuning.co.uk?
  19. Anthony566
    732
    111
    43
    They are close to home so I went and had a test drive with a box ... ended up spending 2 hours testing different maps and picked 4 I liked. One thing that I like is that you can post the box back and Andrew will update the maps if better ones come along. I am in the process of recording some with and without numbers from my car around mpg and 0 to 60 with a gps tracker not really scientific but more of an idea of the difference.
  20. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,926
    199
    I'm a big fan of the Tunit, used them on numerous cars and only poitive results
  21. ABYSS
    940
    524
    93
    results from our own 2.0 170TDI TT
  22. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,410
    648
    How does the graph work?
  23. BigGreg
    121
    32
    That's huge Torque so early in the range. I take it that was the +3 setting? Looks like the clutch would be pushed transferring that.
  24. Tom5190
    Tom5190 Active Member
    318
    139
    43
    The first two peaks you can see (going left to right) are your Torque figure, the second more linear pair are the BHP figure. Torque is a measured value and BHP is a figure calculated from torque & rpm. Essentially you can't measure BHP you can only measure torque and rpm.
    simply: BHP = (RPMxTorque)/5252
    judging by the wheel vs engine power I would guess that was a 4wd TT. For real world terms you should concentrate more on the WHP not the BHP. 4WD systems increase drivetrain loss, in simple terms a 200hp FWD car will transmit more power to the road than a 200hp 4wd car, obviously there are a whole host of other factors in real terms.
    Andrew have you got any graphs with the lambda on?
    Liquidfusion-S3 likes this.
