Diesel power button
dieseldoug Jun 29, 2013
  1. dieseldoug
    dieseldoug Member
    240
    53
    My wife has just found out how to get the extra power from the car by pushing the accelerator pedal down on to the switch to get the extra power from the car. Then she mentions WHY I didn't tell her before typical woman!! But anyway she is very impressed with the extra power, you also hear the change in the note of the engine while this in use, MPG who cares.
    SJW likes this.
  2. NHN
    29,345
    1,719
    Put a rubber block about an inch in height under pedal & say it was a software glitch, which has now been fixed so its slower, lol.
    SJW likes this.
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    isnt that just the kick down? it is on my 8p anyway?
  4. NHN
    29,345
    1,719
    Yes but his is a manual, so it cant kickdown as such
    hittchy likes this.
  5. Vertigo1
    Vertigo1 Well-Known Member
    3,392
    550
    It only works when Drive Select is in efficiency mode in my experience - obviously it's keeping some power in reserve for economy reasons. In dynamic mode it does nothing at all. Not sure about the other modes.
  6. NHN
    29,345
    1,719
    So the manual does have a kickdown stopper on the pedal then?
  7. dieseldoug
    dieseldoug Member
    240
    53
    I will check the mode it's in but it halls ass all the time, I know it will not be in economy mode that's for sure..... Nothing to do with kick down on manual transmission!,!!
    I will find out more and report
    icebun likes this.
  8. hittchy
    hittchy Active Member
    557
    74
    It's not a 'kickdown' as such but similar in feel. There is a point of resistance at the end of the throttle travel similar to that found on auto models. I only drive mine in Auto or Dynamic mode and I find it doesn't do much at all, beside fully open the throttle. I guess if you weren't pushing the throttle all the way down, you weren't exploiting the full power of the car anyway. I find I very rarely need to push it down so far!
    It may well be that it functions differently in efficiency or comfort modes though as has been stated above.
  9. hittchy
    557
    74
    I refuse on principle to drive in efficiency. :)
    The whole point of buying diesel over petrol was so that I didn't have to worry about economy!
  10. markwiggy
    markwiggy Third Gear
    1,132
    94
    Only really use Dynamic, did drive the return leg of a 70 mile round trip (35miles) in efficiency mode only to achieve 3 mpg more. Think my car will live in Dynamic mode from now on.
    Mark
    SJW, dieseldoug and hittchy like this.
  11. johnhugh
    johnhugh New Member
    9
    I have a 2.0 S Line 3 door and in efficientcy and auto l also find that mpg is worse than in dynamic - hence it stays in dynamic.
  12. Vertigo1
    3,392
    550
    It has a similar "stopper" whereby you have to push a bit harder to overcome a little resistance, then the pedal moves a bit further.
    It's obviously not "kickdown" though as it's not affecting your gears, just seems to give you all the engine's power when in the efficiency mode.
    I use Dynamic all the time and it does absolutely nothing at all.
  13. Gordo77
    Gordo77 Well-Known Member Team Navarra Audi S3 Manual
    1,192
    2,286
    Is it only the diesels that have this...?
  14. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,551
    1,165
    On cars I've driven with the speed limiter option (no idea why Audi didn't include this, I use it all the time in my car!), it overrides the limit temporarily when you push past the resistance point
  15. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,687
    526
    My petrol 1.4 also has this button
  16. dieseldoug
    dieseldoug Member
    240
    53
    I have not been back out to the car to check the mode it's currently in, but when my wife is on the button she has just joined a fast flow of traffic and having to accelerate fast hence she will also be doing between 3300-4000 RPM also so she aint hanging around....
    This is usually in 2nd to 4th gears where she has broken the speed limit of 70 anyway..
  17. Gordo77
    1,192
    2,286
    Hmmm... is it cars that have cruise control fitted then?
  18. dieseldoug
    dieseldoug Member
    240
    53
    The car isn't fitted with cruise control.
  19. dieseldoug
    dieseldoug Member
    240
    53
    Just checked the car manual page 85 which states this "button" is a kick down used in manual gearbox cars when in ECO mode. This will give the car more acceleration when pushed.
    But we use the car in auto and use the "kick down" button which changes the engine noise of the car and it appears to change the acceleration of the car also.
    When you check page 85 it will also refer you to page 129
