Diesel Chipping
Alex P Oct 18, 2007
  1. Alex P
    Alex P New Member
    13
    Right i though this came up all the time but after looking through the forum i couldnt find it.
    i am about to chip my 1996 90bhp 1.9tdi A4 and am asking are there any other parts that i should upgrade before doing this?
    Thanks in advance
  2. inigoj
    inigoj Member
    263
    If you are getting a 'generic' remap for your 90 (125-130bhp) i would not change any hardware.
    You could add slightly larger injector nozzles, either 110bhp (0.205µm) or larger V6 TDI (0.216µm) nozzles, and then have a remap that takes the increased fueling into account.
    Much more power and your clutch (which is a weak point on the 90bhp cars) may need upgrading.
    If you want maximum power, add even larger nozzles, more efficient/larger turbo, more efficient intercooler and straight through large bore exhaust, then remap for the hardware and buy a stronger clutch when your old one wears out.
  3. Cviji
    Cviji Member
    58
    How many horses could you get out of that set up out of interest?
  4. inigoj
    inigoj Member
    263
    On a 90 or 110, you are probably looking at around 165-170bhp.
    If you can fit a very large turbo, you can have much more power 250bhp+, but your car will not really be driveable (powerband very high), and engine & gearbox components will start to fail a lot quicker.
    The A4 longitudinally mounted engines have limited space for a large 'down pointing' VNT turbo, not to sure on the room for a 'upwards from manifold' wastegated type.
