Did they make a Revision G Diverter Valve?
controlz Mar 26, 2013
  1. controlz
    controlz Member
    54
    I'm in the process of arranging a remap on my 2008 facelift S3 with W8 Performance, and can't work out whether my Diverter Valve needs changing.
    The valve that's currently fitted says 'G' on it, and I was under the impression that it needed to be upgraded to a Revision D... but I've been told it may be a Revision G!?? :sadlike:
    Help would be appreciated - thanks!
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Go for Rev D
  3. GuyJ
    GuyJ Member
    58
    13
    Think he is asking if they made a revision g as his DV has a "G" on it
  4. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
    Yes they made a g and d value ;)
  5. Kelza
    3,078
    605
    G value [​IMG]
    D value [​IMG]
  6. Kelza
    3,078
    605
    D value part number ...
  7. Ginger Prince
    Ginger Prince Member
    189
  8. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I wouldn't bother with d, g is fine it's the latest revision so someone has had it fitted within the last 12 months or so
  9. controlz
    controlz Member
    54
    Rs3kel recently told me that the G valve came on 2008 cars, and then the Revision D was released... I can't imagine the previous owner changing the valve so I'm sure this is what came with the car in 2008.
    I'm now really confused with all these different answers! If G was the most recent valve, then what was the standard on 2008 car?
  10. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    06F 145 710 C and 06F 145 710 G were diaphragm type DV's.
    06H 145 710 D is the later type piston type DV.
    Note the difference in part numbers, from 06F to 06H.
    G is NOT a later revision of D. It is a different part.
    Thus the mass confusion.
  11. MrLapou
    1,233
    121
    Rev G is much more durable compared to previous types. Made by Pierburg.
    Can be had for not a lot of money like this one.
    eBay
  12. controlz
    controlz Member
    54
    How can I be sure whether mine is an original G valve installed with the car in 2008, or a revised G installed later?
    Would your suggestion be as a precaution, to fit a Rev D before remap, or get the remap with the current valve and see how it is?
  13. controlz
    controlz Member
    54
    Shameless bump...!
  14. OVRA3
    1,079
    80
    I've got the g on mine and I'm running a stage 1 about 245bhp+ and to date it's been great no dramas I'd stick with what you've got when you get the map they will check requested boost vs actual anyway so you'll know if there is a problem. Lots of the guys on here have the d rev but horses for courses
  15. controlz
    controlz Member
    54
    245bhp stage 1? The car has 260bhp in stock form.
  16. OVRA3
    1,079
    80
    Mines a tfsi a3 not an s3 and if they are putting a rev g on the s3's you'll be fine im sure
  17. controlz
    controlz Member
    54
    I'll be at 300-310bhp though, so it's considerably more power.
  18. OVRA3
    1,079
    80
    There are lots running the g mate if you are worried the d is less than 50 quid so whack one in
  19. audicruiser
    audicruiser Audi Heaven
    1,865
    Rev D is the latest and the best one. For the sake of £50 and considering how much easier they are to change on the S3 I'd stick one in ready for your remap.
  20. Kelza
    3,078
    605
    G is the old value ,D is the new value ,forge also do a value for the tfsi cars ..:)
  21. controlz
    controlz Member
    54
    Thanks, athough I am no mechanic myself so will need to get it done by a pro!
    Rs3kel - appreciate your advice as always, but I often can't understand what you mean... remember I am a complete n00b!!S aying the G is old vale and D is new, doesn't really mean anything to me :idea:
  22. audicruiser
    1,865
    Basically the part number of the valve you buy must end with a D!
  23. lincoln_dj
    lincoln_dj Active Member VCDS Map User
    471
    61
    sorry to bump this old thread! But there is some conflicting info I believe. Just been to R-Tech for a remap (from 268 to 365hp) and I'd fitted a rev D diverter valve. They said it should be the G type, as that's the newest/best, and swapped it out for a rev G.
    I'm sure either is fine, and both better than rev C, but I don;t believe D is actually newer than G? Can this not be confirmed on something like EKTA?
    cheers
  24. veeeight
    6,849
    4,760
    Check the part numbers. And are they talking about the piston type or diaphragm type?
  25. audismart
    audismart YOU ARE JUDGED BY THE CAR YOU DRIVE.
    1,327
    284
  26. lincoln_dj
    471
    61
    yeah aware D is piston and the others are diaphragm. I "upgraded" my original rev C diaphragm with the rev D piston. R-tech then told me I need rev G diaphragm type :blink:
  27. Flexiblemouse
    Flexiblemouse Active Member
    258
    60
    Revision D is the piston valve, Revision G is the diaphragm valve. The D will last forever, but is known to leak at high boost levels. The G will hold boost better than the D but will fail eventually. The GFB DV+ lasts forever (with occasional lubrication) but can make the ride a bit jumpy as it slams shut.
  28. audismart
    1,327
    284
    Not noticed any jumpiness with mine mate.
  29. lincoln_dj
    471
    61
    I'll stick with the G for now then, and probably get this GFB valve if that fails!
  30. audismart
    1,327
    284
    Surprised its not failed already with all you have done on your car lincoln.
  31. lincoln_dj
    471
    61
    only got fitted and remapped today lol. might start a sweepstake....
  32. audismart
    1,327
    284
    lol good luck mate.
