Did any one else know this...
marcyp Sep 10, 2009
  1. Nilz
    11,356
    894
    Wiggsy, it can be done on all Audis, but in some cases, it will need to be programmed.
  2. wiggsy
    wiggsy Active Member Team Sepang Audi S3
    193
    69
    programmed? can only the dealer do this? bit of a pi55 take that it doesnt come ready to go grrrr now i know ive not got it i wont it lol
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    wiggsy,my 02 S3 has it or rather did before changing the poor casio alarm are you sure your not pressing it long enough as mine was a bit tempermental or the batteries might be on the way out ?
  4. Nilz
    11,356
    894
    It can lose the settings, mine did for some reason, and had to end up getting it reprogrammed via VAGCOM, if you have a look through the stickies, there is a lis of VAGCOM owners on here, so you might be able to get one of them to sort it for you.
  5. kitpayne
    kitpayne Member
    129
    I have a 99 S3 and it doesn't have the ESP switch - i believe this is because the early ones don't have it? Therefore does it have TC if so does this kick in the same way ESP does (have only had the car a few days and haven't had a chance to find out for myself.)
    If the TC is also as annoying as the ESP, can it be turned off??
  6. Westy
    Westy Well-Known Member
    17,443
    1,105
    If you dont have the ESP button you dont have ESP.
  7. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Whoops...:readit:!
    And just in case anybody missed it...
    Don't forget the hidden compartment in the glovebox! Thats where my tools live!
  8. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    I think some people are mistaking esp for traction control. Traction control on the S3 is pointless, eps is very usefull. Cant turn just traction control off though unfortunately.
  9. kitpayne
    kitpayne Member
    129
    does traction control hold the engine back like the ESP tho????
  10. MintyS3
    1,580
    Traction control uses the brakes and reduces the throttle to stop the wheels from breaking traction. ESP uses the brakes to stop your car from crashing into a hedge backwards when your talent runs out.
  11. Essflee
    Essflee Well-Known Member
    2,148
    67
    Yes, traction control will cut the power if your wheels begin to spin...
  12. Westy
    17,443
    1,105
  13. Ghost
    Ghost Booooooo!
    2,240
    2,131
    Anyone got the built-in digital compass display in the rearview mirror? :cool:
  14. Westy
    17,443
    1,105
    I dont think that was an option, where did you get that from?
  15. giblets46
    giblets46 Member
    156
    Not something exciting, but the air con automatically goes into to recirc mode if you are in reverse (which also automates the rear wiper if your front wipers are active), or you use the windscreen washer.
  16. banoffee
    banoffee Member
    124
    apparently holding the door handle up for a while before unlocking de-ices the locks...
  17. Westy
    17,443
    1,105
    Really? That's a new one
  18. zeeeebo
    zeeeebo Lifes one big laugh
    416
    i found a sat nav from the previous owner in my secret under seat storage in my a3!
    also did you know there is a button on the side piller that de activates the alarm if you have kids in the car!
    does the a3 have a under glove box compartment?
  19. MintyS3
    1,580
    The locks are meant to be heated to stop icing.
  20. Westy
    17,443
    1,105
    Yeah I realised that but do they heat up by lifting the handle? Just thinking about it, it's quite a pointless thing to have with central locking!
  21. banoffee
    banoffee Member
    124
    it's what it says in my S3 manual. I was looking up the autolock thing and noticed it. does seem a bit odd!
  22. zeeeebo
    416
    anotherthing some people dont know is before you turn the engine on press the button on the dash and it runs it thorough a check on all the oil levels and coolant and brakes etc you can see this running on the lcd display on the dash
  23. henners
    henners Member
    62
    How about fiddling with the climate control so that it displays things like speed and footwell temperature etc?
    I'm sure the list of things it can display must be on here somewhere.
  24. audia3vwgti
    audia3vwgti New Member
    and did you know if you press unlock on your keyfob
    then you dont open any door for 30 or 40 seconds
    it relocks the doors then resets the alarm
