DID A DIESEL PURGE TODAY
tdi-man Apr 11, 2014
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    8MM FUEL PIPE USED
    1 INLINE FILTER
    4 FUEL LINE CLAMPS
    1 TIN OF DIESEL PURGE
    RAN CAR FOR 25 MINUTES OR UNTIL JAR IS EMPTY
    Westy likes this.
  2. max69vk
    max69vk Active Member
    862
    57
    Noticed a difference, or any crud in the return filter?
  3. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    What's that do then?
  4. tdi-man
    1,783
    64
    runs the diesel purge can threw the injectors to clean them stuffs been about for years .
    will report back
  5. MattKeating
    MattKeating Member
    248
    17
    Interested to see what the outcome is...
  6. b9rgo1234
    b9rgo1234 New Member
    14
    Did you use a 500ml bottle or a Litre bottle?
    I have heard a few people saying good things about it
  7. YSN
    YSN Member
    93
    What does this do?
  8. Westy
    Westy Well-Known Member
    17,443
    1,103
    Good work again TDI-man :thumbsup:
  9. SmithyAG
    SmithyAG Active Member
    414
    61
    Very interested to hear the outcome of this, as if it works its a whole lot cheaper than having the injectors properly cleaned off the car.
    Westy likes this.
  10. tdi-man
    1,783
    64
    used a 500ml bottle takes about 25 minutes to go threw system.
    my car is pretty responsive any way. been wanting to do this for a while .
    note to any body that wants to do it only use proper fuel line as it will get warm as to will the jam jar.
    early days yet but I have a slight stutter some times on start up and just wanted to see if this fixed it.
    Westy likes this.
  11. Boon
    Boon Active Member
    441
    59
    It won't be as good as removing and cleaning them by striping them down but it can clean some up enough to be acceptable again
    Not used it on the A3 as yet but have direct purged older diesels with good results
    Best way for us to check is with VCDS under injection quantities or similar, it'll list how much work each injector is doing... Sorry can't recall the acceptable differences, a purge will show up before and after results!
    Westy likes this.
  12. SmithyAG
    414
    61
    Absolutely, removing them and having them ultrasonically cleaned is going to be more effective everytime. Would be good to see if this is an acceptable (cheaper) alternative, even if with not quite the same results.
  13. Westy
    17,443
    1,103
    How difficult are the injectors to remove? I have an ultrasonic bath in my garage that I used on my old S3 injectors.
  14. SmithyAG
    414
    61
    Honestly never done it on the BKD engine, however the haynes manual reckons it can be done on your drive with a normal tool kit and potentially a home made slide hammer. Not sure I'd do it myself, I'd probably pay a garage to remove them and then borrow the girlfriends car to take them home and clean them (if i had the gear to do so).
    Everything I have heard/read says make sure you fit new injector seals and ensure they are not even slightly twisted when being fitted, as it causes major headaches.
    Westy likes this.
  15. tdi-man
    1,783
    64
    you should replace the seals when you take them out and the seal kits about £70 for all 4 .
    you have to tighten them down to a certain degrees and have to time each injector up if I remember right.
    not a 5 minute job
    Westy likes this.
