Dials had a spazz??
Oranoco Jun 19, 2010
  1. Oranoco
    Oranoco Well-Known Member
    3,818
    357
    Pulled out to overtake on the M1 last night. As I got to about 90 the speedo and tacho flickered and bounced between 0 and my speed. This lasted about 3 or 4 seconds. Everything else seemed normal and it didn't reappear for the rest of the journey. I'm now worried I might have some electrical gremlins coming my way :(
  2. Broken Byzan
    13,237
    465
    its the new anti speeding campain mate......NOT
    Just watch and see if it happens again i spose, it's not a usual one
  3. Jp-tqs
    Jp-tqs Member
    183
    Had the same problem mate on previous cars! On my rs2000 it was the start of the alternator dying and on my mk3 gti was the crank sensor fooked. Nothing major and easy fixes, hopefully your gremlin might fix itself mate! If you have a volt meter, measure your battery voltage?
  4. Oranoco
    3,818
    357
    Drove home last night and as wall fine until I gave it a hoof full and then the dials dropped back off again and everything just died, total power loss :( It came back and behaved teh rest of the way home. I have noticed now that I'm getting some interference through the radio that I didn't get before.
  5. Broken Byzan
    13,237
    465
    i would start at your earths first, and also check the term 30/75 nuts are tight under the drivers bolster
  6. aragorn
    18,019
    716
    I'd suspect the engine earth strap?
