Diagnostics
jonnysimm Aug 15, 2014
  1. jonnysimm
    jonnysimm jonnysimm
    194
    Hi everyone was wondering if anyone has a scanner around the northwest Manchester/Liverpool area. I want to scan my car to see if there is any problems plus I need to reset my service indicator because it's due in about 10 days. I have a 2.0l tdi 2010 I am happy to pay someone to do it and happy to drive to you.
    Many thanks jonny
  2. Lewbo
    Lewbo Well-Known Member
    1,266
    104
    To reset your service indicator just pull the right Toggle on clocks out when starting your car and hold for 10 secs this will reset it to 365 days/9000 miles
  3. jonnysimm
    jonnysimm jonnysimm
    194
    O right thanks mate I'll do it this morning then still wouldn't mind if there is someone with a scanner tho I've had the car few months and would like it scanning see if there is any faults the stop start isn't working I'm not bothered but there maybe others that need clearing.
  4. jonnysimm
    jonnysimm jonnysimm
    194
    Tried to reset my service it wouldn't do it ? Do I need to let it run out first?
  5. RS3dan
    RS3dan Member
    178
    23
    I've also tried this reset as stated in the cars log and it doesn't work for me either! A little annoying as I used a fairly cheap scan tool which wrongly set it to 1400 miles haha! Interested to know why this won't work/how to make it work!
  6. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,259
    588
    We are in Stockport and can sort it. Diagnostics, Rolling road run etc.
    Rick
  7. jonnysimm
    jonnysimm jonnysimm
    194
    I would also like to know why it won't work ha I've tried it a few times it reset my oil but not the service. Any help would be great. Thank
  8. RS3dan
    RS3dan Member
    178
    23
    I actually got this to work yesterday, don't know how you lads have tried it but from memory the book implies to just switch the ignition on, which I did, but this time I actually started the engine and just held the reset stalk out - was definitely longer than 10 seconds also but eventually it resets (by showing dashes for a moment)
  9. jonnysimm
    jonnysimm jonnysimm
    194
    Was you pulling it out while turning the key and starting the engine ? Or pulled it out after u had started it. I pulled it while starting the car with my other hand but it didn't work.
  10. RS3dan
    RS3dan Member
    178
    23
    No, started the engine and when it fired pulled the stalk - you don't have to be lightning quick with it or anything just soon after it starts (it will display the wrench icon for quite a while anyway)
  11. jonnysimm
    jonnysimm jonnysimm
    194
    Ok thanks I'll try it again later once I've finished work hopefully it will work.
  12. jonnysimm
    jonnysimm jonnysimm
    194
    Still can't seem to reset it anymore ideas ? I can reset my oil indicator but not the service
