  1. T3nnant
    T3nnant Active Member
    423
    84
    Right im new to audi's (the newer type anyway)
    i dont have a dpf light or warning on my dash, but im interested in removing the box and fitting a straight pipe to the back boxes.
    is it as simple as just removing the dpf and replacing with a bit of pipe?
    where would all the connections go as i know there is a cat type plug and two metal pipes going to it.
    if anyone could give me a hint would be grateful.
    Chris.
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    The engine would help :)
    Get a reliable remap company to do it and get a remap at the same time.
  3. T3nnant
    423
    84
    Ah sorry mate!
    Its a 2.0l Tdi 170 quattro
    im going to get myself a remap, but i have accest to a ramp so i was wiling to do the mechanical side myself, but just curious as to wht problems i might encounter when i remove it and replace with pipe, scared ill get tons of lights and issues.
  4. a6_chris
    1,883
    160
    The remap company will remove it as part of the package - you won't get any lights as the new map removes the DPF from the ecu altogether.
    Tbh just remove the innards of the DPF as it may become part of the mot as a visual inspection for cars fitted with one from factory.
  5. NHN
    29,328
    1,708
    Yes I agree do the map etc at a proper company or you may get warnings, issues.
  6. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,254
    586
    Hi Chris,
    the normal way of doing it is to open the DPF up and remove the innards, then neatly weld up. You can replace with a pipe section but it is added expense and has no benefit. Also you will need to figure out a way of mounting the exhaust temperature sensor etc as this is still needed even without the DPF present.
    Regardless of the way you remove the DPF, you will quickly get dash lights and the car will be in limp mode until you have it mapped out.
    Thanks, Rick.
  7. T3nnant
    423
    84
    sounds like a lot of hassle my way now haha.
    Cheers for all the replies.
    will just stick with it for now!
