detailing 'the tank'
easytease May 3, 2007
  1. easytease
    easytease cheesypeas
    433
    So my poor old tank needs a decent treatment. I am considering a portercable at the end of the month (the sonus package from autopia i guess).
    Last week i clayed her (with meguiers clay kit) washing before and after with goldclass shampoo, the followed with the meguiers stage 2 and then gold clearcoat wax.
    I know the meguiers stuff is pretty 'mainstream' stuff, but the results it gives over turtle wax (for example) is impressive. I do, however, still have a lot of swirls and webbing, as well as a few deeper scratches...
    heres a few (bad) pics to give you an idea olf the colour, and the swirling on the roof...
    http://bobbycock.com/clayed07/
    So, what do you recommend? realistically i dont want to spend more then about £50~ for some decent cleaners/polish sealer and wax. I already have the microfibre cloths etc. This is just paintwork to worry about at present, wheels need a refurb so they can wait.
    thanks in advance peeps.
  2. easytease
    433
    any ideas?
  3. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    Wow, tight budget for all those steps, but here's an idea. Working by PC, I would firstly go with Menzerna RD3.02 Intensive Polish using a light cut pad. This will cost £16.85. I would then go with Menzerna 85RD Final Finish using a polishing pad. This will cost you £14.95. Finally, I would go with Blackfire Wet Diamond All Finish Paint Protection, which will seal the paint and give a wet and glossy look that will really suit the colour of the car. This will cost you £21.95. Just a few quid over budget, but if you though the Meguiars gear was good then these products will blow you away. :)
  4. easytease
    433
    I'll extend the budget if needs be, i want to utalise the products i already have, just find a decent polish or something to work out the swirls and spiderwebs. then a decent wax to bring up the metalic a lot more.
    Thanks for the suggestions,wx. I assume these really need PC'd on to get the best resaults? what kinda speeds am i looking to use?
  5. WX51TXR
    1,452
    14
    Aye, both Menzerna polishes mentioned above need to be machine applied, using light to moderate pressure at speeds 4-5 (after being spread at speed 1). If you want to try to work by hand, the standard version of Menzerna Intensive Polish applied using the white side of a German Pad is the best way to go, but be aware that you won't achieve full correction working by hand. :)
  6. easytease
    433
    time to order a PC then! wheres best/cheapest to get one?
  7. Clark@Polishedbliss
    Clark@Polishedbliss Professional Detailer
    226
  8. easytease
    433
    thanks, already ordered with a 15% discount code from them :D
    then ill be raiding the PB store soon for some supplies
  9. easytease
    433
    seeing as the Menzerna RD3.02 Intensive Polish is out of stock pretty much world wide. can you suggest an alternative please. Looking to place an order today/monday of polish, sealant, pads :)
  10. WX51TXR
    1,452
    14
    Sadly, very little else comes close, but looking farther afield, Chemical Guys Diamond Cut Polishes are okay, and 3M Perfect-It Machine Polish is also one to check out (and probably easily available from your local bodyshop supplier). :)
  11. easytease
    433
    the PO85RD3.02 no good then?
  12. easytease
    433
    Still not got any in stock :( ive got money burning holes in my pocket. Any one want to suggest an alternative bunch of products that are instock in the UK right now.
