Detailing Advice for Novice
Paul Holtom Feb 5, 2014
  1. Paul Holtom
    Paul Holtom New Member
    OK so I have a new S3 on order in Misano Red and whilst counting down the weeks till delivery thought I would use the time to sort out cleaning stuff for it. Whilst I have always cleaned cars myself rather than use say a car wash I want to spend a bit more time and effort on this one to keep it looking great.
    Plan is to get it pro detailed from new and then maintain myself on a weekly basis. Due to where I live access to pressure washer is difficult so it will be a hand wash and polish.
    This is what I already have, is there anything missing or anything that would be better for the colour paint.
    Wheels
    Valet Pro Bilberry Wheel Cleaner​
    Poorboys Wheel Sealant​
    Bodywork
    Valet Pro Citrus Pre-Wash​
    Chemical Guys Maxi Suds Shampoo​
    Autoglym Tar Remover​
    Collinite 476 Wax​
    or
    DoDo Juice Hard Candy​
    or
    DoDo Juice Need For Speed​
    Glass
    G-Techniq G6​
  2. sabaxter
    sabaxter Active Member
    465
    27
    As with all detailing products are recommended purely by personal preference. Personally I find meguiars ultimate range are cost effective as well as being effective at keeping paint in great condition.
    Personally I only use a pressure washer to use my snow foam, I believe pressure washers can be dangerous although others would recommend there use.
    You have a great selection of detailing products there so I would try them to see if they achieve your desired finish. If not try the meguiars ultimate compound, polish and wax.
    There is my input and I'm sure many other members will recommend products that they use. Try different products and see what is best for you or ask your detailed what he/she recommends
    Regards Shaun
  3. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,969
    1,647
    I'm with Shaun, I think you have a good selection there. The only thing I could see that was missing was a quick detailer. I can recommend:
    FinishKare #425 - Ultra Slick Polywipe
    or
    Chemical Guys - Synthetic Quick Detailer
    I've also used Gtechniq C2v3 after washing. It's a spray sealant but as it's water based a lot of people use it in a QD style.
    If you are having your car pro detailed I would ask the person doing it what they recommend as a top up. Also if the wheels have been pro detailed and sealed, you shouldn't need your wheel cleaner. Shampoo and water will be fine. Basically let the pro do their job and ask them what you should do to keep on top of it.
  4. LukeTripod87
    LukeTripod87 Active Member
    373
    52
    If you are getting it professionally detailed new then I'm guessing it will be polished then sealed/wax afterwards. Depending on the car's usage the paintwork only needs to be polished 2-3 times a year, it's the wax/sealant that needs to be used more. A couple coat's of Collinite 476 would last you a good 3 or 4 months. Giving the bodywork a good spray of quick detailer after every time you wash it will help keep it looking shiney! :)
  5. R90 STL
    R90 STL Well-Known Member
    615
    299
    not using a pressure washer or hose of some kind prior to hand washing is just asking for swirl marks IMO
  6. scotty76
    2,969
    1,647
  7. Paul Holtom
    Have access to a hose, just not the electric for a pressure washer.
  8. R90 STL
    615
    299
    that would be much better than just going straight at it with a hand wash! just make sure you get yourself 2 buckets with grit guards and a lambswool wash mitt to minimise damage to paint
  9. Paul Holtom
    Two buckets and Mitt already have and just ordered some Angelwax QED and Elixir so should have everything now.
    RobbieWebs and scotty76 like this.
  10. R90 STL
    615
    299
    nice one. be aware that detailing is a slippery slope haha you will be constantly buying stuff
    Welshquattro likes this.
  11. Welshquattro
    Welshquattro Active Member Team Mauritius quattro Audi A4 Audi Avant Owner Group
    756
    136
    43
    You have got most of the basics. Spray over with the Citrus pre-wash and hose off after ten minutes before using the buckets and mitt!
  12. Dimokslis
    Dimokslis Member
    65
    Will Revitalise paint correction system | Auto Finesse help to get rid off of all those:
    Or are there better/cheaper ways to to that?
    I've got clarke 6 speed polisher, that I will use for the job, and it will be very first time, that I am doing anything with body paints. :)
    Any advice welcome.
    Thank you.
