DENSO IK24 on K04 @ 1.6 bar
A4_DTM Feb 23, 2010
  1. A4_DTM
    A4_DTM Member
    115
    Does anyone run Denso IK24 on 2.0 TFSI K04 with 1.6 bar boost (~24psi) ? Did you feel any performance gains over stock ones? How is really cold start with them, something like -20c (-4F) ?
  2. navnayyar
    navnayyar Member
    756
    i thought ik22 are for the 2.0tfsi?
  3. A4_DTM
    A4_DTM Member
    115
    People recommend Ik24 as a 2 step colder plug than stock, for high boosted cars. I just want to know if they are worth of install and if they are capable of firing the car on really cold temps in winter :)
  4. navnayyar
    navnayyar Member
    756
    my mate runs ik22 and are fine
  5. A4_DTM
    A4_DTM Member
    115
    What boost is he running ?
  6. navnayyar
    navnayyar Member
    756
    revo stage2 not sure what boost, id say its 1.6bar
  7. mrgicm
    mrgicm Phantom black S3/
    137
    Good question, ive been considering them for a while now...my mate on his astra opc had them installed and said it was much better...
  8. A4_DTM
    A4_DTM Member
    115
    I ordered them, we will see how they will play on my car :)
  9. A3simon
    A3simon Active Member
    982
    40
    where did you order them from
  10. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    I've been running NGK Iridium BKR8EIX (which are 2 steps cooler than the 6's that are recommended). This is with stage 2 set up.
    Cold start is OK, but a bit patchy with the car idling a little rough. Once you are up to temperature and giving it the beans it feels very good (almost like the extra boost isn't hurting the car so much).
    However I was talking to someone about it last weekend and they said if an engine is running properly (e.g. modified, but within reasonable parameters) you should never have to deviate from the recommended heat setting, only upgrade the plug used.
    Urban legends, opinions, myths.... who the hell are you supposed to believe???
  11. KRL
    KRL Member
    521
    I am interested in this topic as I believe my spark plugs could be causing a flat spot I am experiencing at ~4400 rpm.
    The plugs I was looking at getting are these ones which are 1 step cooler than stock:
    NGK IRIDIUM IX spark plugs - BKR7EIX
    http://www.jkm.org.uk/performance/tfsimisc.htm
    My car has covered 28k (8k of them at stage 1) so I think it is probably time for a plug change anyway as they have not been changed yet.
  12. A4_DTM
    A4_DTM Member
    115
  13. A4_DTM
    A4_DTM Member
    115
    First I will try with IK24, if everything will be ok then I'll leave them, if not I'll put IK22 (I ordered them also just in case)
  14. Iggu
    Iggu Active Member
    1,229
  15. A4_DTM
    A4_DTM Member
    115
