Dension GW 100 help
Aidy06 May 31, 2013
  1. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Hi, just purchased a GW100. I have a Concert 2 radio, connected it all up but nothing is working at all. Plugged iPod in and nothing, instructions say go via CD changed buttons but I've never had a CD changer. It's driving me mad, any help would be much appreciated. Thanks in advance
  2. s8craig
    1,753
    56
    Does the GW100 have a loose black wire? If so you must connect that to the concert II ground. The Concert II will automatically see the attached GW100 as a CDC and pressing the CD button switches between CD & CDC.
    Aidy06 and NHN like this.
  3. Aidy06
    412
    19
    No mate it doesn't, I'll make one. Where is best to connect it?
  4. s8craig
    1,753
    56
    What do you mean is it doesn't have one? Maybe you can post a pic of the harness
  5. Aidy06
    412
    19
    Sorry mate, it does have one - my apologies. Is there a certain place that this has to go? Thanks again
  6. NHN
    29,420
    1,740
    He already advised where to connect it :)
  7. Aidy06
    412
    19
    I don't know what the ground is ha, do I just wrap it round a screw maybe???
  8. NHN
    29,420
    1,740
    Connect it to the thickish brown wire that's in the top left - terminal position, marked as pin 8 of the 8 pin connector.
    Aidy06 likes this.
  9. Aidy06
    412
    19
    Thanks Nigel, appreciate it. Didn't realise that would stop it working, I'll have a look at it tomorrow
  10. NHN
    29,420
    1,740
    Just as a test, making sure you have radio code to hand incase it doesn't remember your vin, remove that connector, temp push the black wire into the back of brown terminal/wire & plug back into radio, then test & see if works, that way before you strip/wire in "properly" you will know if this is the issue.
    Aidy06 likes this.
  11. Aidy06
    412
    19
    Will do buddy, thanks again for the info. Will have a look at it in the morning, hopefully that is the issue and its an easy fix
  12. NHN
    29,420
    1,740
    Was mostly Craig tbh, but he's probably down the pub lol.
    Aidy06 likes this.
  13. Aidy06
    412
    19
    Haha no worries mate, will report back tomorrow
  14. Aidy06
    412
    19
    Thanks Nigel & Craig, got it working. Thanks a lot, really appreciate the help. Was ready to throw it out the window at one point haha, one more question though. How do I access albums? It's all very complicated ha
  15. Aidy06
    412
    19
    Never mind I've figured it out, quite complicated but I'll get used to it. It's times like this that I miss my Golf with the iPod armrest connection and RNS510 ha
  16. NHN
    29,420
    1,740
    Then why not fit an rns-e & ami :p
  17. Aidy06
    412
    19
    Its on my list to do eventually ha, Dension is just for the time being. Only cost me £40 so can't complain
  18. Aidy06
    412
    19
    Any of you two know how to shuffle an album or playlist by any chance? Can't seem to figure it out at all, thanks
