deionized water rinse?
Starry
S3 8V saloon... APR Stage 2....(-:
Bristol
Anybody use this method on here? Im thinking of giving it a go if its not to expensive.
Any recommendations?
Oh yes... :yahoo:
As recently posted in the ASN thread "My mind is made up.....No more wax......" #27:
I NEVER wax. Used to, and I do have the time (way into retirement), but no more.
For 5-years now, maybe more, I wash each car (RS3, TT, and A1) with 1-bucket of clean tap water (sad, I know) and a dash of Simonize wash and wax. I then quickly rinse with DI water - tap water running first through an Aqua Gleam '30' ppm filter and then an Aqua Gleam '0' ppm filter.
Aqua Gleam
Summer and winter the same. No need to dry-off, either. And the same filters for 5-years now...
And when possible, and regularly, a fast/quick wipe over with Poor Boys Spray and Gloss Quick Detailer or Poor Boys Quick Detailer QD+, whichever comes to hand first; and that's it, alloy wheels an' all.
The Poor Boys sure makes the DI water run off faster...
Oh, and no polishing scratches or swirls...
Reactions: NevMan, Raiden, Bristle Hound and 2 others
I'm hoping to start doing this soon. Options I know of:
- Aquagleam (as above)
- Raceglaze http://www.raceglaze.co.uk/race-glaze/400-litre-0ppm-car-washing-filter/
- DI Resin Vessel (ebay, daqua, etc)
- Pure Final Rinse https://purefinalrinse.co.uk/
I cannot fault the Aqua Gleam...
Note #1: if you go Aqua Gleam make sure - if you want to wall mount - to get the filter-brackets.
Note #2: I also use a dedicated hose (reel) - garage to driveway - just to ensure the 'hose' remains full of de-ionised - rather than tap - water.
Reactions: NevMan and Bristle Hound
I’ve been using an Aquagleam filter for a while now, still doing a great job
Reactions: NevMan and 45bvtc
I think ill give it a go, do you just buy bags to refile it after it stops working?
Do you guys use a water tester to monitor hardness?
How many wash's would you get from a 7 litre roughly?
45bvtc, i see you are using 00-ppm and 30-ppm, whats the reason for this, is it because your water is really hard?
Tia..
Tia..
Our Staffordshire-water is medium to hard. I had a '0' ppm filter for 'bonsai' purposes but as that was low use so I thought I'd just couple the two together - '30' ppm first and then through the '0' ppm - and be done with. For sure the '30' ppm filter does most of the work. That said, I've been using the arrangement for 5-years and no worries.
Oh, and the filter is sealed so just wait for the resin to change colour and fit a new filter. OK, it would not be a problem to 'split' the filter and change the resin but I just don't see the need, easier to swap a filter and be done with.
5 years is a long, long time. Thats good to hear. Do you monitor the water with a meter?
No, I monitor the car paintwork and glass checking for any deposits left.
It's amazing how little DI water I actually use washing a car, the DI water is used to 'rinse' off the wash bucket water.
Like I say, just monitor the colour of the resin.
Reactions: Starry
Currently using the AquaGleam at the minute, but the race glaze will be my next purchase when the AquaGleam decides enough is enough. Really is a great purchase, and helps anyone’s OCD.
Reactions: 45bvtc
Reactions: 45bvtc and Bristle Hound
Is anyone using a rainwater harvesting solution?
I have a rainwater collection system connected to the main house gutters and collected into two linked 25 gallon slimline water butts with a Hozelock water pump that feeds a dedicated retractable mini hose reel. With our levels of rainfall I’ve never ran out of water, and it’s been a couple of years now. Pretty sure the neighbours think I’m mad though.
I live in a hard water area, and used to find calcium watermarks on the car after washing with tap water (no filters) Now l wash as normal, using one bucket + lambs wool mitten (Gtech shampoo) and rinse off using the rainwater as l work my way along the car in sections.
The rainwater tested as neutral for acid/alkali.
Would there be any benefit to adding a filter inline with the rainwater feed? I’ve always thought rainwater is already DI, but I’m no expert.:racer:
Sorry but what about the acid rain that comes down after you used demin on your car lol
And why not. For sure a filter would remove suspended debris but otherwise why not. Mind, I prefer to use my rainwater for my greenhouse tomatoes and cucumbers during the growing season but out of then care of the cars come first.
DI water for me is used best during the winter months when I can't be bothered to wipe-down.
Whatever works for you is always best.
A 2013 Daytona grey Audi A1 after a DI wash - and not waxed for 3-years - just off to dry the brakes:
A1 di wash scribble
Reactions: voorhees and Jassyo06
Unfortunately my driveway leads down the side of the house directly into the attached garage, so don’t have space for bigger water butts.
I’m surprised your getting 38ppm from rainwater, though thinking about it, if you have any crud in the guttering, that’s getting washed into the rainbarrels as well.... I will have to think about adding some DI filters on the output of the butt pump!
Reactions: scotty76
I've considered loads of ways of fixing this. Had a good chat with a guy at the local aquatics centre about fine filter pumps and such but it gets expensive. Fish need things that Audi paint does not. :) I think I'll probably go the Pure Final Rinse option as it's less faff than DI Resin changes. I'd love to have solved the rain water problem but it just doesn't seem cost effective.
Ive just checked my ppm with a meter i bought and its coming in at just over 400ppm... am i reading this right?
It says on the web site that its 237ppm but thats a lot lower than the reading from my meter.
And that's consistent with the UK water hardness map, Starry:
Water hardness
Aqua Gleam filter/s for me seemed the most cost effective solution to my car washing summer and winter; and house window washing to include a glass conservatory roof, too; so many uses. Hate to think what it would £s cost to specialise coat three Audi...
Thanks bvtc for your help.
Am i right in thinking the Aqua Gleam are not refillable?. I was looking at the 7 ltr Raceglaze canisters, they come full of resin for £99 and they're refillable at a cost of £45 for. I think ill go with the 30ppm and see how it goes and if needed run it through a secondary 00ppm filter.
They are sealed, Starry, but that doesn't mean you couldn't split 'em and refill; for sure I'll be looking at that one day.
And here's a 10-minute wash and rinse on the A1 - like just now - ready for a run in 20-minutes or so:
Wash and rinse
And no water spots after...
Reactions: NevMan
Do you know how many litres the AG version holds? I love washing and polishing my cars but i hate drying them, at the moment I've got a leaf blower and 4 large micro fibre towels i use.
4" dia x 10" long so 125 cu inch and that's about 2 litres :readit:
@Starry local water company website says 241ppm hardness. TDS meter says 240ppm so my reading is pretty close. TDS meter was something like £3 off ebay. I run the tap for 10 seconds, collect a sample in a clean glass and then measure it.
Thats how i collected my sample but it was just over 400ppm. Ill try again with more time running the tap 1st.
Reactions: scotty76
OK. Just wanted to let you know in case it helped. 400 is possible but if that is the true reading it's going to chew through water filters. :grimacing:
Reactions: Starry
Just re-done mine, got a 333 to start with then left the meter in the water and within 30/40 seconds it went up to 404. If left in the water does yours rise?
And after 30+ wet miles yesterday and overnight rain here's this mornings bonnet beading:
Bonnet beading A1
Reactions: NevMan and Starry
Just for you I left it a full 2 minutes. :) Still 240.
IMG 20180330 090613309 1512x2016
Reactions: Starry
Maybe I’ve bought a dud meter. Is there a way of testing it in a known ppm? Bottled water? Something like that.
The reading does rise but not massively. It started at 237 for me.
What meter do you have scotty76, do you have a link? Let me know and I'll order. I'll then take readings of 1) tap, 2) after single-pass '30' ppm filter, 3) after single-pass '0' ppm filter, and 4) after combined '30' ppm + '0' ppm dual-coupled Aqua Gleam filters as I have now.
Who says retirement is boring...
Reactions: scotty76
