Definitive answer, RS3 brakes fit under 18" Rotors without spacers?
VAG_BADGER Aug 11, 2013
  1. VAG_BADGER
    VAG_BADGER Ricers in the rear view!
    100
    As the title suggests, I have a brake upgrade to fit to my 2009 S3 from the RS3. The car has the 18" rotors fitted and I was wondering If spacers will be required? I've seen a few threads on here discussing the setup requirements but it appears some people say they will fit without spacers and some people say you will need 10-12mm spacers to clear the wheel? Just after a definitive answer before I do the upgrade and can't get my wheels on!!
    Thanks in advance all!
    DB
  2. JamesS4cab
    JamesS4cab Well-Known Member
    1,190
    94
    Is the brake setup from the RS3 or the TTRS?
    If it's the former, you will be in for a nasty suprise with the discs as they are the wrong offset and do not fit. You need the TTRS ones.
    With regards to the rotors, mine are 19" 8.5J ET43 and they fit with plenty of room to spare. I cannot answer for your specific wheels i'm afraid.
  3. VAG_BADGER
    100
    Thanks for the reply, thats bad news for me then!! They did indeed come from an RS3, or at least that is what I was told. The part # for the disc is 8P0615301 so i'm guessing the info I received was correct. Not the end of the world, i'm guessing the calipers are the same?! Didn't give a deal for the lot to be honest so I'm not overly fussed. Don't suppose you have a part number for the TTRS discs do you? Typical that the ones of an 8P don't fit and the TT ones do!
    Cheers.
  4. jav3n
    jav3n New Member
    My disc part no. is 8PO615301. Was told by my local workshop that it can't fit onto my S38P. Am stuck with it now not knowing what I should do.
  5. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    They are the old discs anyway and will likely squeal like a *****!
    For reference the part number off my RS3's front discs is 8PO 615 301B. You will likely have the old callipers too.
  6. JamesS4cab
    1,190
    94
    you both have the RS discs then - that sucks.
    The TTRS discs are 8J0 615 301 and they fit no problems.
    Calipers are the same fit so all is not lost! The recalled calipers were only fitted with two sound deadening devices to the back as far as i'm aware. Brake squeal can be reduced using anti squeal shims which are £5.00 delivered. I have the "older" discs and have had zero issues with squealing.
  7. RYes3
    919
    198
    43
    Yep they have some anti vibration weights on the back. I think there is a PDF floating around somewhere from user 45bvtc which shows how you can cure the squeal on the original discs/callipers.
  8. JamesS4cab
    1,190
    94
    The PDF states that the anti squeal shims should be used and thats what i have done with zero squealing thus far.
  9. VAG_BADGER
    100
    Thanks all for your help & advice, much appreciated. I will have to try and track down the PDF you speak of just incase I get the squeak.
    JamesS4cab - Did you bother running with the TTRS disc backplates or did you just leave it with none? Can't see the point as I know the AP racing kits etc run without? I'll update the thread when I know if the 18 Rotors fit! Suck it and see...
    Cheers.
  10. Dean_T
    Dean_T Active Member
    645
    139
    43
    An update would be great, when you can of course :)
    I have 18" rotors same as you and want to know what brakes will fit under them....
  11. NME
    NME Member
    150
    19
    Thinking of fitting a set of these myself, but just wanted to know if you need any extra bits for the fitting beyond the existing setup on the S3?
    I plan to get a TTRS MC later on, but as far as all hoses go, do they just connect up to your existing setup?
  12. JamesS4cab
    1,190
    94
    I can confirm categorically that 18" rotors WILL NOT FIT over the RS callipers. Done. EPIC FAIL. Not even close. Ended up wedging the wheels over the caliper and marking the inside of the rim.
  13. Dean_T
    645
    139
    43
    Did you try with spacers too?
  14. JamesS4cab
    1,190
    94
    No point. The inside of the rotor wedged onto the caliper. Spacing it out would make zero difference as it was the barrel of the rim and bot just the outer edge as it usually is.
    Poor picture as it was late and we were both pissed off by now:
  15. Dean_T
    645
    139
    43
    Ah, ok, sorry didnt read your previous post correctly.
    Gutted for you :(
    I was hoping they would fit as this is what I'm planning - looks like the only answer is new wheels :(
  16. JamesS4cab
    1,190
    94
    Not my wheels bud. Was helping a mate out as well as creating a definitive list of what does and doesn't fit so others benefit!
    My stock s3 rims fit fine so I'm happy!
