Default DIS display?
Lapchien66 Feb 21, 2010
  1. Lapchien66
    Lapchien66 New Member
    27
    Whenever I start up my A3 I get the navigation display in the DIS, and I have to click it over 3 times to get back to the 'normal' temp, miles remaining etc display. Can you set the DIS so that it displays this latter view by default, instead of the NAV each time?
    Lapchien
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    On mine the navigation only comes on in the DIS when you have a route selected. If you cancel any route on the RS-E it should start on the normal DIS
  3. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,292
    2,686
    Not tested it myself, but I think I remember reading something about turning the compass display off in the RNS-E might sort this.
  4. matt_white88
    matt_white88 Member
    254
    Is it possible to retro fit a DIS display?
  5. andykn
    andykn Member
    166
    I've heard that, if you have DSG, the DIS is fitted to show the gear and can be fully activated using VAG-COM (VCDS) coding.
  6. Khufu
    5,704
    31
    You will have errors for any sensors you are missing though eg, screen wash level etc.
  7. matt_white88
    matt_white88 Member
    254
    Ah I have not got DSG will have to give this a miss then and get it on my next A3, had it on a MKV Golf as a courtsey car and really like the DIS.
