Debadged and took the lacquer off!!
BigWillyStyle Feb 4, 2013
  1. BigWillyStyle
    BigWillyStyle Member
    566
    58
    Ok so on Saturday i decided to take off the A3 and 2.0TDI badges off the back using dental floss.
    Badges came off easy but oh my days the glue wouldnt! Used 'Sticky stuff' remover and a Spatula numerous times and it still wouldnt budge! Never had this problem before! So i had the choice of either leaving it on and it looking a mess or scraping it off with a knife!
    I knew using a knife would take the lacquer off, which it did, but thought it would look less noticable than the glue.
    I've used T-Cut to try and smooth it but still looks a bit shoddy so i was wondering what else could i use and if there is nothing else, could i just get the lower part of my boot lacquered fairly cheaply to rectify?
    Thanks!
  2. Artimus
    Artimus Shortback
    2,017
    485
    I used Farecla G3 and plenty of elbow grease to clean mine up after I moved the badges up and in a little! it took a few attempts to get it looking right though.
  3. BB13
    BB13 New Member
    22
    if you have taken the lacquere its a repaint, A good body shop will be able to do a part respray on the damage area and blend it in.
  4. Lewis583
    956
    91
    As said. One the lacquer has been taken off its repaint time I'm afraid.
  5. BigWillyStyle
    566
    58
    Ah balls!!
    I've Debadged before but its been easy compared to this. It was like someone put the badges on themselves and used No-Nails or something.
    How much do you think it would cost approx? Not had any spray work done for a looooooooooooooong time!
  6. NHN
    29,576
    1,779
    If trying to remove sticky double sided tape, just buy yourself a caramel wheel, brilliant things I have a stock of them :)
    stuartm likes this.
  7. BigWillyStyle
    566
    58
    ............. i dont get it :tumble:
  8. NHN
    29,576
    1,779
    Which part?
  9. BigWillyStyle
    566
    58
    The whole thing. I've been around Chemicals today so i think some brain cells have been killed off....
  10. NHN
    29,576
    1,779
    Do a search for caramel wheel.
  11. BigWillyStyle
    566
    58
    Ahhhhh right haha.
    I thought it was a joke!
    Never heard of them! I have all of the glue off now so would this be any help with the lacquer as in, will it smooth it out?
  12. Artimus
    Artimus Shortback
    2,017
    485
    ChipsAway are supposed to be pretty good and fairly cheap @ £80ish per panel.
  13. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro saloon s tronic
    1,511
    387
    Lol I just used white spirit... took the glue straight off and left no marks whatso ever and still nothing and that was 6 months ago. Knife... 0_o !!
  14. BigWillyStyle
    566
    58
    Sh*t the bed!! Think i'll just wait until the dirt covers it haha!
  15. NHN
    29,576
    1,779
    & when the dirt gets into the metal & rusts, lifts paint & lacquer, thats the bootlid below line/top of bumper needed doing at vastly more.
  16. hades-
    9,482
    646
    didnt you heat it up first ?
  17. Boon
    Boon Active Member
    441
    59
    Methylated Spirits for removing trims and badges :thumbsup:
  18. Danny-boy
    Danny-boy Active Member
    511
    25
    Scary, I'm doing mine at the weekend.
    Meths and hair dryer already at the ready.
  19. BigWillyStyle
    566
    58
    Yeah it just wouldnt budge! It didnt look like normal glue either,Well,not what ive been used to in the past!
    Good luck, hopefully have no problems like me!
  20. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    When i de-badged mine i simply used a spatula/scraper and leaved the badges off the car.
    Once this was done it left the adhesive from the badges, i used UPVC cleaner to take the majority off and they polished the rest off. Personally i wouldn't use T-Cut as you can achieve the same just using different grades of polish.
    And with views on the re-spray you more than likely will have to get the full door painted, as blending would be a nightmare.
  21. READER84
    READER84 Member
    247
    Reckon mine wants de-badging but like on previous cars it takes time and patience!
  22. robbiemac
    robbiemac 'S' Button engaged....
    733
    388
    I'm due to replace chrome Audi decals on rear and front bumper as I've purchased high gloss black replacements however...... after so many conflicting opinions and reports on 'how to' remove existing decals I stopped and decided to get professional detailers to do the job when the car goes in for detailing work in April...... Sorry for you're troubles mate
  23. BigWillyStyle
    566
    58
    Its the boot so hopefully because of the part where the boot has the line above the plate it should be easier to blend! Fingers crossed if it needs doing!
    I had alot of patience.....for a change....but then the knife came out!
    Haha wish i did that now!
    Not your fault mate but hopefully yours turns out better!
    robbiemac likes this.
  24. grr666
    grr666 Member
    171
    19
    Tardis works well removing sticky residue.
  25. NHN
    29,576
    1,779
    Even some chicken thin wire from a diy store can cut the foam backing away from the badge, then use a caramel wheel to remove all the sticky residue, then just quickly rub over with a cleaner, then polish with some G3.
    Caramel wheels are used by professional bodyshops, to remove the sticky foam tape to fit new trim etc parts that have these to fix to the car.
  26. BigWillyStyle
    566
    58
    Thanks for the info. I'll know for the next time if a debadge a car in the future.
    My main problem now is just trying to smooth the lacquer until i get it corrected but T-Cut has done all it can do!
  27. TimG
    TimG Active Member
    942
    45
    Why don't you put some badges over the damage mate? ;)
  28. BigWillyStyle
    566
    58
    Haha to be honest i did think about putting them back on until i got it sorted!
  29. riggssuzuki
    riggssuzuki Active Member
    502
    57
    Hair dryer and WD40.
    In fact I washed the car with WD40 to get rid of tar spots. It was superb. Followed that with a snow foam, rinse, shampoo, rinse, dry and polish. WD removes anything sticky and is not too harsh. Just be careful around the wheels!!!!!!! Discs dont like it!!!! :asskicking:
  30. READER84
    READER84 Member
    247
    +1 for WD40, top stuff!
  31. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Seems like a daft question, but does anyone know how you would go about sticking badges back on once you've taken them off? I ask because I'm thinking about taking the rear 4 rings off, spraying them black and sticking them back on.
  32. BigWillyStyle
    566
    58
    The same **** that someone used to put the badges on the back of my car with lol. Only comes off with a knife!!
  33. NHN
    29,576
    1,779
    Buy a new ring badge, paint it then stick, trying to fit new sticky tape to the shape of the rings would take ages considering the rings arent exactly expensive overall.
  34. Artimus
    Artimus Shortback
    2,017
    485
    sorry ...couldn't resist.
  35. TimG
    TimG Active Member
    942
    45
    I took mine off and painted them black. Used those number plate sticky pads to reattach it - but it did take ages to cut the adhesive into the correct shape and to look neat! managed it though.
  36. leeds2592
    1,399
    222
    Cheers lads. I'm going from working 5 days to 3 days soon so I'll have a bit of time on my hands. May give it a crack and if I balls it up, buy new rings.
    You don't know a price of the rings from the stealers do you Nigel?
  37. robbiemac
    733
    388
    eBay..... Underground parts, roughly £12.50 for the small Audi rings decal.
    you can order in High Gloss Black or matte Black, the rear badge has the adhesive backing already fitted.
    And once you've ordered that, you might need a can of this to coat the A3, S3, RS3 badges you may have.....
    I am going through this conversion now, decided to hand over the car and parts to a professional detailer as my skills are not up to it......
    good luck with you're project.
  38. Just debadged mine this morning, nice easy free mod, hairdryer and meths came off no problem.
  39. slizza786
    slizza786 Active Member VCDS Map User
    399
    27
    I'm planning to dip my whole car by the end of next weekend so I'll make a thread on how that goes. I'm doing the same thing atm... Iv debadged the whole back and looking to dip my rings black then remount it back on but I can't seem to find any 3M adhesive anywhere. What glues are u guys using to put it back on?
  40. JimboS3
    JimboS3 Active Member
    261
    134
    43
    Dang!... The thought of going anywhere near my cars with a knife makes me cringe! you stoopid! Hang your head low in shame pay for a good paint job and leave it to the experts in future.
