Dealer Service - NOT!
imported_Kyoshi Mar 8, 2006
  1. imported_Kyoshi
    imported_Kyoshi Guest
    I recently had my A4 Quattro serviced by my local Audi dealer, they mentioned that the two rear diff seals were leaking in the report that I received so I decided to have a local garage take a look to give me their opinion on the seriousness of this reported item. I was shocked to hear from the local garage that although the Audi dealer mentioned the leaking rear diff seals, they did not check the diff oil level - we know this because the local garage pointed out the corrosion around the diff plug showing that it's not been opened recently.
    The local garage also noticed that one of the brackets for the exhaust was missing, this was not reported by the Audi dealer - I have been informed by the local garage that a missing exhaust bracket is a MOT failure!
    My question to this esteemed forum is this... Is the reporting of a missing exhaust bracket and checking of the diff oil level part of the Audi service? I would like to know before I go in with all guns blazing.
    TIA!
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You're really wasting your time & money getting a 9 year old car serviced at a Dealer.
    They're not interested in older vehicles and ouch £90+ per hour?
    £800 for a cam belt change??? Are they mad? Oh and don't bother changing the water pump while you've got the front of the car off, I'll pay another £800 in 6 months time, that's if it hasn't seized up, stripped the new cam belt and knackered most of my 30 valves.
    Complete to$$ers the lot of them.
    Find a good independent specialist who actually cares and you'll get far superior service and save a fortune.
  3. PaulJC84
    PaulJC84 Owner
    2,920
    17
    Yeah i agree with AndyMac.
    I would expect them to notice the exhaust!!
    The oil level of the diff may be only checked at certain services though. I would expect them to notice the oil coming out the diff as well as its pretty easy to see.
    Where in Scotland are you and what dealer did you use?
    Cheers,
    Paul.
  4. docurley
    4,073
    88
    Use a specialist in the future as they tend to be more customer based.
    As they had noticed a leek I would have thought they would at least check the level of the dif and yes a bracket is an MOT failure and no I would not expect them to notice it as its not part of a service.
  5. alanmclean1974
    alanmclean1974 New Member
    19
    I had they same list of problems with my 2000 plate A4 1.8TQ. Oil leak at diff, water pump, timing belt, and incidentally, they did notice one bracket on my exhaust had become detatched from the exhaust. They did not advise it was an MOT failure though. And now I've removed it and binned it !!!
    I had mine done at Glasgow Audi, maybe its all a standard footer on the bill !!
    Alan
  6. imported_Kyoshi
    My dealer is Highland Audi in Inverness. I am disappointed though that they didn't check the diff oil level when they noticed the leaks at the 80k service. However, on the other hand, I've been told previously by one of their technicians from a past service (when the diff oil leaks were initially noticed) that as long as there's no oil lying on the ground from the diff seal areas it's nothing to worry about. I was also informed by them and a local garage that if the diff seals were replaced they would leak again... sounds strange - can anyone enlighten me to what that's about?
    I note that a missing exhaust bracket is not part of a service check so I'll let them off with that one.
    I know that a dealer is more costly than others but have always found them thorough with a great customer service. I had the timing belt done and they charged me nowhere near the £800 that has been quoted by AndyMac, it was more like £200!!!
    Thanks for everyone's opinions, much appreciated!
    /ubbthreads/images/graemlins/laugh.gif
  7. madvw
    madvw Active Member
    2,489
    you had a service from an audi dealer yes?
    the simplest way to check is to have a look at the service inspection checklist, which you should get given from the dealer after your service.
    On here it should state clearly what was checked, and the state in which it was found.
  8. imported_Kyoshi
    I didn't receive a service inspection checklist from the Audi dealer.
  9. jcb
    jcb Active Member
    4,132
    13
    standard servcie has a list of things they service, if diif oil is not on it then they won't do it.
    Dealers are sharks, they make there money on servicing.
    Where are you based, you say Scotland. Did you got to Audi Edinburgh? Even worse than most dealers........If you are try autowerks on Goorgie road.
    Top quality. they check everything, services are great and the workmanship is spot on.
    Full 4 wheel alignment and adjustment less tahn £90.
    They a re Bosch specialist and deal with a lot of Porsches as well
  10. AndyMac
    9,832
    46
    "I had the timing belt done and they charged me nowhere near the £800 that has been quoted by AndyMac, it was more like £200!!!"
    I don't think so! The parts alone cost more than that and it's at least 5 hours labour as the front of the car has to come off.
    The only reason it would be cheaper is if they didn't bother to change the tensioner and the water pump. In which case you'll have to get it all done again pretty soon.
  11. fallmonk
    fallmonk Turbo Sport
    1,868
    [ QUOTE ]
    [/ QUOTE ]
    Am with andy on this one , dealler charged me £650+ for timing belt and as the same as andy never advised me to change water pump thankfully unknown to me the water pump had been changed AND the timing belt done by a specialist (obviously someone who knows them a damb site better that the dealers)
  12. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,462
    3,026
    My local dealer quoted me £680 last year for the cambelt (water pumpt not included). My local indie (top class people) did both for about half that amount.
  13. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    Are there any good specialits in or around Glasgow then???
  14. JayB5UK
    JayB5UK Member
    471
    [ QUOTE ]
    [/ QUOTE ]
    Who and where is said Indy? I'm struggling a bit down here...
  15. fallmonk
    1,868
    [ QUOTE ]
    [/ QUOTE ]
    Hi mate i use Donalson Motor Co , he used to be down at the SECC but due to the area being refurbed hes moved to Clydebank dont know if this is any good for you? his number is 01413390077 thats his old number but im sure he would have transfered it, any problems just PM me and i will get new number IF there is one also try
    Volks-Ways
    260, Hamilton Rd, Cambuslang, Glasgow, Lanarkshire G72 7PF
    Tel: 0141 641 0641
  16. C_Audiboy
    822
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    hi mate i use donalson motor co , he used to be down at the SECC but due to the area being refurbed hes maoved to clydebank dont know if this is any good for you? his number is 01413390077 thats his old nu,ber but im sure he would have transfered it any problems just PM me and i will get new number IF there is one also try
    Volks-Ways
    Tel: 0141 641 0641
    [/ QUOTE ]
    Nice one fallmonk, cheers for that /ubbthreads/images/graemlins/beerchug.gif
  17. fallmonk
    1,868
    no prob mate hope it helps
  18. easytease
    easytease cheesypeas
    433
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    i've got my A4 B5 booked into fontain ( www.fontain.co.uk ) for cambelt change with pump etc, along with anual service, brake fluid change and i think aircon service. all for £611. fantastic price, and they lend me an A2 to play with /ubbthreads/images/graemlins/laugh.gif
  19. jdp1962
    8,462
    3,026
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Sanspeed, in Bexleyheath. They're only five minutes walk from my house, but a bit of a schlep for you, I guess.
