Dead Pixel Repair is it this simple?
rasA4 May 17, 2010
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    saw this on eBay
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250633837383&ssPageName=ADME:B:SS:GB:1123
    it says
    "This manual will show you step by step how to remove the unit, fix it and replace. It should take you about 1 hour (or less).
    All you need is a screwdriver, no other tools or technical knowledge is required.
    cant be this simple can it? i do recall that on the A3 forum someone IIRC recommended to heat the DIS connections. however it had mixed reviews and experiances
  2. cerips
    cerips Member
    54
  3. rasA4
    3,287
    119
    looks informative however dont look that easy
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Gave that a go on mine and it didn't help at all.
  5. rasA4
    3,287
    119
    which one the eBay one? or the zine?
  6. adesb5
    adesb5 Member
    34
    i did the e-bay fix it didnt work on mine and ive got loads of dead pixels which is a bit of a pisser
  7. Blue_Thunder
    1,776
    33
    It's the same from what i've read on other forum posts. Wedge cardboard behind the ribbon cable and screen.
  8. calvin
    calvin parked up
    155
    fwiw I took mine to bits and tried the ebay type repair, wedging some fine strips behind the ribbon cable - it made it better, but mine also suffered from fading in heat, so in the end bit the bullet and got it replaced by Clusterrepairsuk.co.uk - for about £100 all in as i recall. fully functioning, guaranteed and tested..
  9. Kingfisher
    Kingfisher Active Member
    283
    51
    Mine done by Cluster repair ( but it was £160 not about £100 !! )
    Again fading as it warmed up and after an hour or so you couldn't see anything + pixel problems.
    It took them 1 hr 20 mins, while I waited ( actually she spent about £60 in Debenhams and about £8 for a couple of coffees + cake..... while we waited ) and they are use to doing it.
    Reckon an hour is a bit optimisic....
  10. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    HA HA HA !!! SOUNDS FAMILIAR!!!
