Dead Battery S-Tronic stuck in Park
chrisb72 Jan 26, 2013
  1. chrisb72
    chrisb72 Active Member Team Panther Audi S3
    237
    72
    My battery is completely dead and my car (A3 2.0T S-Tronic) is stuck in PARK so I am unable to push it out of my garage to jump start.
    I don't own a battery boost charger, I only have a trickle charger. My idea is to leave it for a good few hours to charge with the trickle charger in the hope that I can engage the ignition and get it out of PARK.
    Does anyone else have any other ideas?
    Sadly I don't have home start relay.
    Also my battery is only 10 months old and I am a bit surprised it has lost so much power. I know it has been very cold and the car hasn't been used for a long run since Xmas, but I used the car for a short run 2 weeks ago. I did at the time feel the car hadn't jumped into life, but by the time I had used it for a few miles it seemed ok. My concern is that something is causing it to drain, but I can't think what?
    Any help and opinions very welcome.
    Chris
  2. scoobyc
    scoobyc Member
    34
    The manual gives you a way around this. I think there's 2 model variations on the s-tronic but you basically lift/pry up the gearshift surround and there is a small clip that you push to allow you to select neutral and then push the car out. I've not got the manual to hand or I'd give you more details, sorry.
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    You may need to 'rock' the car to release pressure on transmission 'pin' as the lever is moved to N.
  4. Lewis583
    956
    91
    I wouldn't bump start it, that's even if the gearbox will allow you to so so. Just leave it on charge until there's enough to fire it up. Takes longer but your power train will thank you for it.
  5. chrisb72
    237
    72
    I managed to manually switch the gearbox into N with the help of the manual.
    I did attemp to push the car our of my garage but my drive was too steep for two grown men (maybe we need more Weetabix) so it's now on a standard battery charger borrowed from a friend to hopefully charge over night.
    I think I may need to get the battery checked as I feel that it should have held its charger for longer.
  6. NHN
    29,413
    1,740
    Grab yourself a Ctek MXS 10, it is brilliant & also has a 12v supply mode which would allow the electrics to run whilst batteries dead as such, done numerous times & I use it for any radio/12v work aswell so has numerous uses, so worth the money, charges brilliantly.
  7. L1ARR
    L1ARR Active Member
    433
    44
    Agreed, best £90 I spent. They work a treat and really do the business.
