DEAD BATTERY AFTER 4-5 DAYS ON MY RS4 2007
mickeystewart Aug 7, 2011
  1. mickeystewart
    mickeystewart New Member
    9
    I Have a RS4 2007, i went on Holiday for 1 week and parked my car in the airport carpark, when we came back the battery was completely dead.
    Bump started the car and has been fine since but if left for more than 4 days then the battery goes flat.
    I have no idea what could be draining the battery, any ideas of common faults for this?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,764
    661
    Some Bluetooth modules have caused this, however you would also notice you bt module would be dead.
  3. NHN
    29,352
    1,720
    Unplug your radio & see if this helps, if not then unplug your BT module, these as already mentioned are know to suck power.
    I can supply/fit replacements if faulty, give me a shout if of any help.
  4. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    you might need to replace your battery as it could of just got old and past its best
  5. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    I have a suspicion he may be sorted by now :)
  6. LYRAC
    LYRAC Member
    125
    Just had to replace my battery as all of a sudden NOTHING jump starterd and ok, left overnight and guess what? No power again!! New battery magic BUT can you help lost all bluetooth connection for Phone and voice command. Help its a nightmare!!
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Check the BT module for fault codes using VCDS.
  8. NHN
    29,352
    1,720
    Assuming its a audi bt unit, as PD states, but fuse may have blown aswell, does the radio work ok as if its a factory fit , iirc they share same feed.
