De locking on a sportback,
Biggy Apr 30, 2013
  1. Biggy
    Biggy Member
    115
    13
    I wanna de-lock the drivers side door on my sportback, is it a case of fitting a rear door handle? Or is it more complicated?
  2. jimojameso
    jimojameso Active Member Team Nardo Section Mod Audi RS3 TTRS
    405
    181
    43
    Be careful just incase your battery goes flat :)
  3. Biggy
    Biggy Member
    115
    13
    No one?
  4. mike foster
    3,967
    Don't think you will get an answer because I doubt very much if anyone has done it.
    Why would they ?
  5. jimojameso
    405
    181
    43
    You could just take the handle off, fill and then smooth it if a rear one is different.
  6. davc
    davc Well-Known Member Team Glacier Audi S3 quattro saloon s tronic S3 Saloon
    690
    714
    93
    Fitting a rear door handle should be fine if indeed they are the same size.
    My mk4 golf was delocked and I was still able to open the doors when I had a flat battery. There should be enough juice in it to operate the central locking if it happens.
  7. max69vk
    max69vk Active Member
    862
    57
    If you want to de-lock the drivers door (God know why though, if you shut the keys in your screwed) order a passenger side door handle assembly for a left hand drive car, the lock is only even on the drivers side so it will be 'de-locked'.
