de-cat the lambada sensors
phoenixv6quattro Jul 15, 2010
  1. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Hello Gents hope most of you are well.......
    I'm going to be de-catting my 2.8 30v v6 tomorrow with some straight sections (strategically timed a week after the MOT emmisions test!). Will there be a requirment to change the Lambada sensors or will retaining the standard ones be ok? Many thanks in adavance if anyone can answer thsi?
    Ollie
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
  3. Jonion
    Jonion Member
    193
    Well it is hot stuff !
    The std lambda sensors should be just fine.
  4. phoenixv6quattro
    1,396
    Thanks gents. Your quite right Blue, there is a disco going on under the bonnet.............I added a syllable because I was in a good mood this morning (******-I didn't know how to spell it) Thanks for doing a google search for me ref the pic. It's excellent to know you are taking the time out for me. Now go and put the kettle on lad.
  5. aragorn
    18,545
    865
    depends if you have two or four.
    If you only have two, then so long as they stay in the pipe everything will be fine.
  6. millsy
    millsy Member
    55
    how did the decat go?did you weld or clamp the decat pipe?am looking into doing this myself,but have read that the downpipe is cast,and difficult to weld and is made brittle?i was considering buying the ebay s4 decats,and cut off the s4 flange and weld on the 2.8 jobbie in its place.
