De-cat bad for the turbo?
HIGGINS Dec 12, 2011
  1. HIGGINS
    HIGGINS Member
    528
    15
    Basically ill try and cut the story down.
    I have a custom straight through cat back and i went to my local exhaust place to get them to remove the cat. They basically said they can do it but it could destroy my turbo within half a year as it will be spooling up too quick.
    Is this true? :S
    Im sure theres ALOT of people with straight through pipes
  2. sportstractor
    sportstractor Chugger
    2,709
    Not true, that's why turbos have a internal waste gate. Just sounds like somebody trying to be a know it all
  3. HIGGINS
    HIGGINS Member
    528
    15
    I mean i didnt believe it really my self but i thought it must be true as they are an established exhaust centre :S
    So should i just get it done? :p
  4. sportstractor
    2,709
    What car is it? You don't get cats on diesels?
  5. sportstractor
    2,709
    Oh iv just been informed you do get cats, but they are different to petrol cats.
    I personally wouldn't remove it, unless you massively modding it ( ie bigger nozzles, custom map)
  6. dunk
    dunk Member
    770
    Audi diesels have a cat, and you can remove it and still pass an mot. Removing it will improve flow, increase turbo spool and reduce turbo temps- particularly worth it if you use a hybrid turbo that usually spool slower cos of the heavier compressor wheel
  7. George 1982
    George 1982 Member
    35
    I've just bought a decat for my 130 pd before I go in for a remap.....hope this line about killing turbos is wrong !
  8. adamss24
    adamss24 Well-Known Member
    4,557
    394
    Some small turbo's are known to surge and by removing the cat you experience "boost creep" which means the turbo overboosts even with the vanes fully closed ! Surging is very bad for turbo/engine as it can lift heads and snap the shaft which almost every time could lead to hydrolock !
    If you have a KP39 or Garett GT1749 Va i suggest you leave the cat in place ! I would remove the cat if you have a bigger, slower spooling turbo...
    gupsterg likes this.
  9. Gaz!
    Gaz! Member
    159
    14
    Any need George? How is it?
    Would anyone know the turbo fitted to the 130 pd 2002 engine please?
  10. adamss24
    4,557
    394
    GT1749VA, read my above post...de-cat will work but do not expect it to last a lifetime !
