De-Badge or Not?
Lee540 Apr 26, 2013
  1. Lee540
    Lee540 Member
    123
    10
    Hi all,
    I know how to de-badge.. just contemplating whether to or not?
    The A3 and 2.0TDi from the boot lid and the s-line from the front wings.. have many of you done it? I like the clean-ness of de-badged car, I did it to all my previous vehicles.
    Have many of you done it?
  2. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    When I got my car, it was already debadged! If it wasn't though, I'd of done it myself as it looks much better IMO.
    I think the majority of people on here have done theirs as well.
  3. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    do it! :rock:
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
    Defo do it, debaged mine and dewipered. Clean as u like from the rear.
  5. Lee540
    Lee540 Member
    123
    10
    De-wiper really? Suprising how much **** gets all over the rear window on a wet drive out..
  6. Sidhu88
    808
    76
    My rear wiper wasn't working so rather than spend £90 on a new motor, i paid £2 for a grommet spent about an hour doing it myself and happy days. I use rain-x which helps alot with rear view vision but yeh when it gets dirty its an issue but nothing that a quick clean can't sort.
  7. southylad
    southylad Active Member
    544
    do it mate i did mine looks a lot better, and the s line on the wing i have never liked those
  8. sammi
    sammi Active Member
    345
    45
    Unless its an rs or s badge mine would have been long gone!
  9. Avnt
    Avnt Active Member
    240
    25
    De badge ppl cant tell its an oil burner then lol
  10. Ultra Violent
    Ultra Violent Sick & Wrong. Team Solar Audi S3
    1,159
    314
    Def do it.
    looks much cleaner.
  11. Persian
    Persian CEO Audi S3
    270
    21
    Just like everybody else I also prefer just the audi rings on the back and front other then those nothing else. However I don't like the idea of de-wiper.
  12. garuf
    garuf Member
    130
    Mines de-badged and de-wipered apart from the rings, toying with the idea of taking those off the back though.
  13. autolatry
    autolatry Active Member
    347
    67
    I have taken the badges including the rings off the back of mine. Looks a lot better.
    There was a lot of glue behind the rings though but still only took an hour to do
  14. TDI140
    TDI140 Well-Known Member
    1,623
    174
    dewipered it how do you clean the rear screen coz mine get filthy as anything
  15. Wicked666
    Wicked666 Active Member
    584
    35
    I dewipered a saxo years ago due to a heavy sound system in the boot. Also had limo black tints. Once you get used to just using your side mirrors, you realise you don't need to necessarily look through the back. Like a van driver.
  16. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Lol mine had a big dirty 2.0TFSI Quattro badge on the back with a red T. It's much more fun destroying other A3s off the lights without the badges.
  17. soulsurfer
    soulsurfer Member
    141
    9
    So how do you remove the badge without cocking up the paintwork?
  18. autolatry
    347
    67
    I used boiling water to get the badges off and Autoglym tar remover and a plastic ruler in a tea towel to get the glue off. No damage to the paint but my cars 9 years old so you can see a difference in paint colour. I am going to t cut it to see if it makes a difference.
  19. s3reptdi
    s3reptdi Member
    179
    I wouldnt use boiling water IMO! I use dental floss too get behind it and work it off then use a bodyshop toffee wheel (these can be called different names) on a drill at a slow setting, then use Carplan tar remover as i found this to be much better than autoglym
  20. southylad
    544
    hair dryer and plastic aa membershp card, then meths, then cutting agent, then polish ,worked a treat no damage atall and cant see where they were
  21. s3reptdi
    s3reptdi Member
    179
    granted cutting agent does wonders, especially if you have a dual action polisher, but even plastic will scratch your paint, personally dont use meths, hairdryer yes but be careful
  22. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    Soon as he puts the foot down you will......lol
  23. southylad
    544
    iv allways used meths on any badge residue with no probs whatsoever mate , and the card used carfully as you worm with the hairdryer worked well with no scratches or marks i just used t cut or the like to go over the area as when you first remove the badges you can see the difference in the paint where they were so a good t cut and pollish and no sign
  24. Wilonso
    Wilonso Member
    78
    15
    Mine took me 15 minutes, Hairdryer to heat up the glue then prize it off using fishing line, the remaining glue residue i sprayed with APC left agitated a little then rubbed the majority off. Any remaining glue residue i heated up with the hair dryer and rubbed a micro fibre over it and it gripped to the micro fibre and rolled up into small balls. Repeated till all was gone. My car was only 2 years old so there was no difference in colour.
  25. CHEZ
    4,171
    839
    wd40 works good too for removing the gum left behind! Then use t cut to remove the shadow left behind
  26. Persian
    Persian CEO Audi S3
    270
    21
    Best method I have used is hot water first to weaken the glue then use dental floss and slowly run it underneath the badges.
    To remove the glue use Autoglym Tar Remover works perfectly.
  27. soulsurfer
    soulsurfer Member
    141
    9
    Did mine today, removed A3 2.0 TDI from the tailgate and the S-Line badges from the front wings of my Black Edition. Dental floss with fishing line lube after warming up with a hair dryer, peeling off the remaining badge tape and cleaning off the residue with WD40. Final buff with rubbing compound and job's a good 'un ;-)
  28. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,975
    537
    +1 debadge.
    i've removed badges on front and back, and it looks so much better. liking the sleeper look.
  29. audicruiser
    audicruiser Audi Heaven
    1,865
    If you know your Audis then you can tell!!
    Keeping the badges shows you have nothing to hide!
  30. soulsurfer
    soulsurfer Member
    141
    9
    ^^^ What a load of rubbish, of course you can tell, it's about aesthetics, that's all ;)
