DBC Cruise Control
aragorn Aug 7, 2009
  1. aragorn
    18,444
    848
    Does anyone have a working cruise control system on a DBC car that could check some things for me?
    I'm struggling to get mine working, despite everything seeminly checking out properly so i'd like to clarify a few points against a working system.
  2. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    mine also isnt working so would like to hear the outcome of this
  3. aragorn
    18,444
    848
    yours is an S4, so its almost guaranteed to be the stalk at fault.
    DBC cars use a mechanical vacuum system with a small hella ECU box to run the cruise, your car just interfaces with the ECU directly.
  4. S4twiggy
    1,815
    9
  5. Broken Byzan
    13,237
    465
    Grant can put you in touch with a guy breaking one with a working stalk.
  6. aragorn
    18,444
    848
    Fixed it :D
    Seems i'd made an **** of the brake lamp connection, due to a misunderstanding of the troubleshooting guide (i pulled it from the live side rather than the bulb side), and i think the first ECU was faulty too.
    Second ECU fitted and the brake take off rewired and its working :D
    Gonna recheck the first ECU in a bit to ensure its defo duff, but smiles all round.
    The stalk is a bit funny, but thats not unusual for used CC stalks. I might take it off at some point and clean the switch contacts inside.
