Dashboard warning light???
CycleSi Jul 4, 2007
  1. CycleSi
    CycleSi Member
    A warning light has appeared within the 'speedo dial' on my S3. It is a picture of an engine, but I can't find any details in the owners manual about it.
    I think it came on after I pulled away hard with the ESP turned off - l felt a little bit of wheelspin and then it gripped as normal.
    What am l likely to have done and how do l fix it?:lmfao:
  2. S3DanP
    S3DanP New Member
    29
    A colleague of mine had the same problem on his V6 Golf 4-Motion, I think it turned out to be a sensor of some sort, I'll ask him tommorow and let you know for sure.
  3. CycleSi
    CycleSi Member
    Thanks - l suspect l may have 'upset' a sensor. Ooooops !
  4. petewon
    petewon Member
    529
    thats the CEL (engine managment) light, could be anything. Best off getting someone to scan it with VAG.COM.
  5. CycleSi
    CycleSi Member
    Do I have to go to an Audi stealer to get that done or will a normal garage/independent be able to scan it?
  6. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    indy vag garage should be able,just phone around
  7. S3DanP
    S3DanP New Member
    29
    Hiya,
    Found out from my mate on his 4-motion it through out the brake light switch, sounds odd but thats what it was when examined by VW. (he said check your brake lights are working)
    Hope this helps
  8. golf
    golf ***** rent boy VCDS Map User
    1,556
    How can people not know what an Engine Management Light is?
    Anyway, it could be a multitude of things. It can be triggered by any error and only a scan would be able to tell you, for certain, what is going on. Otherwise it's just trial and error.
  9. Jampublic
    Jampublic Taking it easy..
    974
    12
    Cycle Si did you get it sorted? A garage could charge you as much a £50 to plug in and check faults, a stealer could charge you a load more!
