Dash light question ?
fallmonk Jul 2, 2013
  1. fallmonk
    fallmonk Turbo Sport
    1,868
    Hi folks ,
    Quick question am I right in saying my dash lights should come on as soon as the ignition is on /engine started ?
    Am sure my B5 did this and other VAG cars I have driven do this, it can be actully quiet dark to see my speed on the dash. Off course I can turn my lights on physically and problem solved !
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Yeah, my instrument cluster illuminates even when the headlights are off.
  3. swarcup
    swarcup Well-Known Member
    1,326
    40
    They can be altered via vag-com to be on or off, just needles lit or needles and clocks together. Maybe someone in the past has had it altered.
  4. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    392
    B6 S4 default settings are Lights off = Dashboard Needles illuminated, Lights on = Needles and dials illuminated.
    The dimming button used at night also brightens and dims the daytime needle illumination.
  5. fallmonk
    1,868
    Cheers guys will see If I can get it sorted next time am with someone with VAG comm
  6. VagCabby
    VagCabby Active Member
    519
    78
    Not sure if its just a cabriolet thing but mine has the clock illuminated in bright light but as soon as it starts to get abit dull and gloomy and if I go through a tunnel they turn off. Theres a little sensor under my clocks. Its obviously there to make you turn your lights on but I find it bloody annoying as it turns them off when its still light. Stupid feature and its not possible to disable in VCDS as far as I can find
  7. A4Ade
    A4Ade Active Member
    106
    There are four lighting modes, which can be changed in adaptation channel 19 of the instrument control module, according to the VCDS website:
    Mode 0: Nothing lit until ext. light on
    Mode 1: Pointers lit all the time
    Mode 2: Scales lit all the time
    Mode 3: Pointers and Scales lit all the time
    I have tried changing this from mode 1 to mode 3 and it doesn't seem to make any difference. Mode 2 does work though, curiously. So it's possible your car is coded correctly and something else is going on... I'm curious to know why it doesn't seem to work for me anyway...
  8. cnut
    cnut Member
    153
    9
    I coded mine so that the instruments are only lit when I flick the lights on. Every car I have had previously was like this so it seems normal for me!
