Dash Indicator Problem ?
J.R. Jan 25, 2011
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Every time I indicate left or right it seem to flash on the dash the opposite side a few times before it goes to the side it so-pose to indicate. It's really annoying :banghead:......Does anybody know how to sort this ?
  2. mike foster
    3,967
    Bloody hell - I suppose you have checked that it doesn't do that outside ?!!!!!!!
    Never heard of that before - maybe NHN or Khufu could help ?
  3. J.R.
    1,405
    68
    Nah I ain't checked it outside yet.....it's very strange ......
  4. golfg6076
    golfg6076 New Member
    25
    Mine has just started doing this. if i indicate left ,its fine but if i indicate right, it flashes left inside and out unless i hold it there..........
    any ideas?
  5. J.R.
    1,405
    68
    ok enough is enough :banghead: ......The problem is getting Worse and I can't stand it no more...
    This is a little video of my Issue ... Look @ when it's 27 sec
    Any Help would be appreciated ...
  6. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    523
    39
    id say stalk contacts are knackered.
  7. J.R.
    1,405
    68
    Ok And you don't think it's the Hazard Relay or anything else ?
  8. Gavin0478
    523
    39
    no coz when it stopped after 27secs when you just touched the stalk it started working again.
    a relay either works well buzz's coz arking or dont work but a relay couldnot cross circuits like that in my opinion.
    i have taken stalks appart on cars to clean contacts etc and although not too complicated id say they could easily cause this if worn.
  9. Gavin0478
    523
    39
    instead of flicking try to slowly move stalk up n down so to speak see if you can find a point where it works correct and point where is malfunctioning.
  10. J.R.
    1,405
    68
    Thanks for your reply ...
    But if you look closely at the vid after 27 secs ...I don't switch it back down ....it appears I was about to ...but I didn't....as it started to indicate the right way.
    It's strange ...because it only does it sometimes....but recently it has got worse.
  11. KevinF
    KevinF Member
    69
    Hi Digzz,
    Long time ago I realise but did you sort this problem out? Replace the stalk maybe? Or the relay switch?
  12. J.R.
    1,405
    68
    I Replaced the stalk.
  13. KevinF
    KevinF Member
    69
    Cheers. Not as easy a fix as I was hoping.
