Dash Display
macattax Oct 20, 2006
  1. macattax
    macattax Member
    455
    The display on the dash with a picture of a car only comes up when the boot is open and flashes for the boot on picture but it doesnt do it when a door is open.
    Does anyone have any idea why this is happening?
  2. docurley
    4,072
    87
    Do the lights come on when you open the door?
  3. macattax
    macattax Member
    455
    Yeah the lights do come on.
  4. docurley
    4,072
    87
    hummmm not the door switches then.I can only think its some sort of control module or the clocks them selfs.
  5. macattax
    macattax Member
    455
    Well I couldnt find anything on vagcom that could fix the problem.
  6. RICH2JOSH
    RICH2JOSH Member
    78
    Wow, I've had my '98 TS for 6 years and have never seen anything that looks like a car on my DIS - Is this option only on a particular year?
  7. macattax
    macattax Member
    455
    Yeah Rich you should have it too.
    I was wondering if having the centraal locking pump replaced has caused the doors not showing as opened on the Heads up display.
    But its strange that it does show the boot open!
  8. RICH2JOSH
    RICH2JOSH Member
    78
    I'm gonna give it a try when i get in tonight as i was just about to place an order for the remote locking kit from Vagparts - If it is the central locking pump i would rather know before hand prior the installation so as to sort out the problem.
    I don't think it would be your pump though Mac unless you totally re arranged the existing wiring.
  9. macattax
    macattax Member
    455
    Well the previous owner kept every single receipt for the car .
    When he said full service history he meant it lol!
    So one of the receipts was for a new central locking pump so thats what made me think that this could be why the doors are not showing up on the display when they are opened,
  10. docurley
    4,072
    87
    In the centre pillar for the front and near the back seats for the rear.
  11. low610
    low610 Member
    125
    My 99 1.8 T Sport has the boot open display but i've never seen it appear for the doors being open.
    I wonder if it's an option within vagcom. I've recently had mine programmed so the doors lock when the car is travelling over about 10mph. Thought it was a good idea at the time but it can be a pain in the ar*se.
  12. macattax
    macattax Member
    455
    I havent seen the option in vag com all i saw was a test for the actual display.
    Lol my gf thinks the auto lock is a pain in the **** but i keep telling her to wait till i take key out before she opens door but she nagged about that too.
    When she opens door before key comes out the backdoors wont auto unlock for the wee fella ffs whats so hard to understand about that!
  13. RICH2JOSH
    RICH2JOSH Member
    78
    Macattax, what year is your car and what type of display do you have as i'm sure mine does'nt even show a car not to talk about doors/boot opening.
    Cheers - Rich
  14. macattax
    macattax Member
    455
    Its a 99 reg.
  15. RICH2JOSH
    RICH2JOSH Member
    78
    That probably explains it Mac, mines a 98 which only has the interior lights remaining on when a door is left open.
  16. John@ECM-TECH
    John@ECM-TECH Owner Site Sponsor
    305
    79
    Sorry to resurect an old thread but I'm getting this anyone have a solution?
  17. macattax
    macattax Member
    455
    I never got to the bottom of it its still something that annoys the **** outta me all the same.
  18. John@ECM-TECH
    305
    79
    Do you get a seatbelt warning? I'm starting to wonder if someone has messed around with VAG-COM at somepoint and caused this.
    I wander if the two are related
  19. macattax
    macattax Member
    455
    I dont get a seat belt warning.
    But I did manage to find the seatbelt code for vag com and switched it on but all it did was ligt up a seatbelt warning on the dash when I turned the ignition and then light went off after a few secs even though I didnt have seatbelt on (there was no chime either)
    It could be related but I doubt it.
    But for the door sensor problem I am led to believe it could be a fuse or (relay?) problem according to my car diagnosis software.
    It says there is a fuse for "door open warning lamps controle module" to be found in fascia 3 of the fuse box which is marked as fuse 5.
    I dont have a clue what they mean by fascia 3 so I am confused on where that fuse can be located.
    The software only gives a schematic of the fuse box so until I find out what fascia 3 means I am stuck!
  20. John@ECM-TECH
    305
    79
    I've PM'ed AndyMac he might know, he seems to be an Ice/Electrical wizard over in the ice forum.
  21. John@ECM-TECH
    305
    79
  22. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    No help here I'm afraid, mines a 97 model and doesn't have the door open indicator.
    Is the fuse not listed in the owners manual?
  23. John@ECM-TECH
    305
    79
    Just looked and can't see a specific one, it must be a knacked relay somewhere I think maybe the "door warning lights relay" where ever that may bem
    Thanks for looking AndyMac
  24. macattax
    macattax Member
    455
    Ok then according to the link you gave Jpc it is relay number 5 .
    So where can relay number 5 be found?
    This would be a highly possible reason for the open door warning lights not coming on imho.
  25. John@ECM-TECH
    305
    79
    Well quoting the forum
    The relay is mounted on the 8-way relay carier, it should be located in luggage compartment, right rear, behind the trim (I think they mean passanger side)"
    It looks like he means in the boot, guessing it will be on the passenger side but it may be the drivers side, hopefully it should be marked with a five.
    Got to remeber this guy is american so the motor will be left hard drive, but since they move the fusebox to the drivers side in right hand drive cars it would make sense that they do the same for the relays.
    Looks like an explore behind the trim in the boot may prove fruitfull, might get a chance this weekend
  26. macattax
    macattax Member
    455
    Well according to my Autotech software "fascia 3" where relay 5 is meant to be is located at the fusebox front driver side?
    But it may be wrong, but best of luck and let me know how you get on.
  27. John@ECM-TECH
    305
    79
    I'm trying to get a copy of ELSAWIN to find out for sure. I'll post the results here
  28. RICH2JOSH
    RICH2JOSH Member
    78
    Im a bit confused too as mine is a 98 which has a door warning sensor which only makes a noise when the lights are left on but no graphics on the DIS.
    Also, no seatbelt warning of any type - does this sound right chaps ?
    Rich
  29. John@ECM-TECH
    305
    79
    Does the display show up when the boot is open?? If so yes.
  30. macattax
    macattax Member
    455
    All I get is boot but it is supposed to show the doors also which it is not doing.
    Also I get the the chime for leaving lights on but not doors open.
    As far as seat belt chimes it doesnt come standard on UK models as far as I know this is a US spec but it is available to be turned on by using vag com.
    I added the seatbelt warning to the car through vag com but I had very little luck with it.
    Somone here must know where Fascia 3 is located in the car ffs!!
  31. naefeart
    naefeart Bonkers
    168
    39
    Is this not refering to the fusebox at the righthand side of the dashboard - sits behind a cover between the dash and the drivers door?
    My 99 QS does exactly the same thing - only the boot brings up the display on the DIS.
  32. AndyMac
    9,832
    46
    Yes, only the Americans need to be told whether their seatbelts are actually on or not. Why on earth would anyone want a chime to tell them?
  33. macattax
    macattax Member
    455
    Lol I know where the fusebox is that isnt what I am looking for although thats where I am sure it should be located.
    What we need to know is where is FASCIA 3!
    ____________________________________________
    Re: Seatbelt issue
    Well you can never trust your passengers can you!
    I think its handy coz I often have to remind my m8s to belt up insurance reasons etc.
    So yes I think its a good idea if it can be switched on somehow with chime.
  34. shineydave
    shineydave Member
    920
    it's under the dash, remove the knee bolster under the steering wheel, iirc the relay is mounted in the second bank under there. there's one bank that's immediately obvious with a second bank hidden behind, you have to get right under the dash to see it
  35. macattax
    macattax Member
    455
    Now we are getting somewhere!
    What does the knee bolster look like?
  36. AndyMac
    9,832
    46
    It's the piece of trim under the steering column, all the relays are behind there
  37. John@ECM-TECH
    305
    79
    am not bothered about the seatbelt chime just the door thing annoys me thats all.
  38. John@ECM-TECH
    305
    79
    Just spent ages in elsawin
    Got some wiring diagrams and it is meant to be in:
    8-point relay carrier:
    Position of relays:5 - Door warning lamps control unit
    Right so this is supposed to be under the dash, ill try to have a look asap
  39. macattax
    macattax Member
    455
    Ok thats good that you know where it is but how will you know if the relay is broken or not?
    Wouldnt you need an exact same relay that you know for sure works?
    How do you get the kneeboard off anyway?
  40. John@ECM-TECH
    305
    79
    I was presuming that you could just swap it temporarily with another relay of the same voltage etc
    Then there is this which I found on the central locking wiring diagram :
    J452 - Door warning lamps control unit - This must be the relay?
    Im gonna be fitting a handsfree kit at somepoint so will have a look at the relay no 5 then.
