dash clock upgrade
jbh Sep 16, 2013
  1. jbh
    jbh TDi lover
    1,412
    168
    right as a few folk have read ive got myself a new set of clocks.
    my car was a base model 110 TDi so it never even had an oil or volt gauge and I felt deprived..
    so ive got a new set of clocks on route from an early 97 TDi quattro so it has all the extra bits on them
    now its the one with no numbers on the clock which mines is the same.
    so heres the info im needing..
    I know once I plug them in it will give me warnings regarding washer level and the oil temp wont work. so has any one got a pin layout on to let me know what I need to add and where.
    also ive got a stalk from a qts but it was removed from a face ift so I presume I need a PFL one. does anyone have one they would be willing to swap me? or sell me
    also any one local willing to adjust my miles? not a major problem I cant see them being higher but I would like to keep my miles correct.
    heres the new clocks
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    If you can wait till the edingboro audi meet id be happy to swap these over and correct the milage etc to suit.
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    ScottB5 has done a lot on dash insert buggering abouts - there was a post somewhere about it but I Can't remember what it was called!
  4. jbh
    jbh TDi lover
    1,412
    168
  5. jbh
    jbh TDi lover
    1,412
    168
    cheers bud ive replied to you're pm
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    The pin outs by Aragorn in my thread should be the same for yours and the new clocks.
    Minus the gauges you are missing.
    Most of it should be pretty much plug and play I think apart from the sensors you are missing.
  7. aragorn
    18,579
    868
    I dont think the pinouts i posted were for type 1 clusters?
    I'll see if i can find them though.
    The stalks changed in ~97, you probably have the earlier type. 98 onwards all use the same one, so the TQS part wont fit. I'll get you the PN of the stalk you need too.
    Your not too far away from me if you need any help getting it working i'm sure we can meet up and have a prod.
    jbh likes this.
  8. jbh
    jbh TDi lover
    1,412
    168
    Ill try and see if the boy i got the clocks from still has the stalk. his car was also an avant so it will have the rear wash wiper option.
    if you can get pinouts that would be great.
    and cheers for the offer of help. I might take you up on that if I run into problems :thumbsup:
  9. @udi A3
    1,819
    197
    After re reading, ignore that price in pm, if its just milage correction just meet me at that meet and prove your milage if i need to reduce it, should only take a few moments, i was thinking you needed to key match etc, but immo1 i dont think you do.
  10. jbh
    jbh TDi lover
    1,412
    168
    im pretty sure the clocks will go in and allow the car to run for what ive read. as you say its immo 1.
    I don't think you'll need to reduce it. my cars got 246k
  11. @udi A3
    1,819
    197
    pop along to the edinboro met then if you can :D
  12. jbh
    jbh TDi lover
    1,412
    168
    well ive stuck them into see what will happen.. the miles on the is 230k my cars on 247k.. so that doesn't make a major difference.
    im getting bulb warning, washer level, right hand indicator not lighting up on the dash ( ive tried changing the bulb ) and the air bag lights come on.. ( [FONT=verdana, arial, geneva, sans-serif]01025 - Trigger for On Board Diagnostic Lamp: Malfunction ) and to top it off... the LCD is perfect..
    [/FONT]
    [FONT=verdana, arial, geneva, sans-serif]ive only got 2 plugs behind my dash I don't have the 20 pin black plug.
    [/FONT]I would like to get these working but I have a feeling there may be an issue with the clocks. hence the indacaitor and airbag light coming on.. unless anyone else has an idea? ive left them in the now as I would like to see if the MPG works
  13. jbh
    jbh TDi lover
    1,412
    168
  14. ScottD3
    15,164
    1,123
    I got a spare 20pin black plug is you want it mate.
  15. ScottD3
    15,164
    1,123
    [TABLE="width: 100%"]
    [TR]
    [TD="class: spalte-text"][TABLE="class: cc abstand-kap einzug-standard"]
    [TR]
    [TD="class: titel-kap"]Any good?
    Pin assignment at multi-pin connectors on instrument cluster - vehicles up to model year 1997[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD="class: spalte-pfeil"] [/TD]
    [TD="class: spalte-marg"] [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: spalte-text"][TABLE="class: cc einzug-standard abstand-standard absatz-hervor"]
    [TR]
    [TD]Multi-pin connector, 26-pin, blue[/TD]
    [/TR]
    [/TABLE]
    [TABLE="class: cc abstand-standard erlaeutrg-leg"]
    [TR]
    [TD="class: einzug-nummer"]1 - [/TD]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TABLE="class: cc abstand-liste erlaeutrg-leg"]
    [TR]
    [TD="class: einzug-nummer"]2 - [/TD]
    [TD]Buzzer activation[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]3 - [/TD]
    [TD]Terminal 15[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]4 - [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]5 - [/TD]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]6 - [/TD]
    [TD]Terminal 61[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]7 - [/TD]
    [TD]Handbrake/brake fault[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]8 - [/TD]
    [TD]ABS (direct)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]9 - [/TD]
    [TD]Airbag (direct)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]10 - [/TD]
    [TD]CAT[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]11 - [/TD]
    [TD]ABS (inverted)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]12 - [/TD]
    [TD]Airbag (inverted)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]13 - [/TD]
    [TD]Right parking light[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]14 - [/TD]
    [TD]Ignition lock S contact[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]15 - [/TD]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]16 - [/TD]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]17 - [/TD]
    [TD]Gong activation[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]18 - [/TD]
    [TD]Oil pressure 1.8 bar[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]19 - [/TD]
    [TD]Terminal 58d[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]20 - [/TD]
    [TD]Coolant level[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]21 - [/TD]
    [TD]Turn signal (right-side)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]22 - [/TD]
    [TD]Main beams[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]23 - [/TD]
    [TD]Speedometer input[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]24 - [/TD]
    [TD]Brake fluid[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]25 - [/TD]
    [TD]Brake pad[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]26 - [/TD]
    [TD]Left parking light[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 26-pin, yellow[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Terminal 58[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Engine speed signal[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Air conditioner compressor[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Clock - output[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Road speed signal 1[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Road speed signal 2[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Door contact, driver's side[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Terminal 30[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Fuel tank warning[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Turn signal (left-side)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Belt buckle switch[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Terminal 31[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Diagnosis lead[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Glow period warning lamp[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Immobiliser[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Fuel gauge sender[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Coolant temperature sender[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 20-pin, black[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Fuel consumption signal[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Ambient temperature[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Gear selection indicator[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Hydraulic pressure[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]On-board computer: reset[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Radio/telephone - clock[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Radio/telephone - data[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]On-board computer, left[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Radio/telephone - enable[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Tail lights / dipped beams[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Glow plug relay[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]On-board computer, right[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Brake light[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 4-pin, black[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Oil temperature sender[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD="class: spalte-marg"][/TD]
    [/TR]
    [/TABLE]
  16. ScottD3
    15,164
    1,123
    [TABLE="width: 1749"]
    [TR]
    [TR]
    [TD="class: titel-kap"]Pin assignment at multi-pin connectors on instrument cluster - vehicles from model year 1998[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD="class: spalte-pfeil"][/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 32-pin, blue[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]1 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]2 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]3 -[/TD]
    [TD]Speedometer output 1[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]4 -[/TD]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]5 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]6 -[/TD]
    [TD]Airbag[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]7 -[/TD]
    [TD]Terminal 31 (sensor earth)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]8 -[/TD]
    [TD]Coolant temperature[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]9 -[/TD]
    [TD]Terminal 31 (load earth)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]10 -[/TD]
    [TD]Oil pressure switch[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]11 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]12 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]13 -[/TD]
    [TD]Glow period warning lamp or CAT[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]14 -[/TD]
    [TD]Self-levelling suspension[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]15 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]16 -[/TD]
    [TD]Trailer turn signal / fault in engine electrical system[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]17 -[/TD]
    [TD]Main beams[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]18 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]19 -[/TD]
    [TD]ABS[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]20 -[/TD]
    [TD]Terminal 58s[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]21 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]22 -[/TD]
    [TD]Coolant level low[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]23 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]24 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]25 -[/TD]
    [TD]K wire[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]26 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]27 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]28 -[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]29 -[/TD]
    [TD]Brake fluid level/pressure[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]30 -[/TD]
    [TD]S contact[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]31 -[/TD]
    [TD]Belt buckle[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: einzug-nummer"]32 -[/TD]
    [TD]ESP[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 32-pin, green[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Transponder 1[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Immobilizer[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]W wire[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Boot lid/tailgate (Lowline version only)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Brake pads (Highline version only)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Fuel tank warning output signal for engine control unit (only on 6-cylinder TDI and on export versions for USA)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Standing time output[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Air conditioner shut-off[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Handbrake[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Electronic throttle[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Parking lights[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Transponder 2[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Oil temperature[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Terminal 58d (external dimmer potentiometer)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Speedometer output 2[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TR]
    [TD]Multi-pin connector, 20-pin, red[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Selector lever position indicator[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Washer fluid low[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]On-board computer reset[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Clock signal for radio frequency display[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Data signal for radio frequency display[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Enable signal for radio frequency display[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Tail lights / dipped beams (bulb monitor)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Glow plug relay (on TDI engines the low-voltage monitor in the instrument cluster is disabled while the glow plugs are activated)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Not used[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
  17. ScottD3
    15,164
    1,123
  18. aragorn
    18,579
    868
    98 is for cars with immo, so it wont be that.
    I'd check its actually plugged in properly first of all!
  19. jbh
    jbh TDi lover
    1,412
    168
    yea im thinking ill double check the blue plug. as I know it was a bit of a pain to do and im seeing that that's the one with the airbag and turn signals on it.
    the boy I got the clocks from did say one of the turn signal lights didint work..
    I might ask him if his airbag light was on.
  20. jbh
    jbh TDi lover
    1,412
    168
    think I will need this Scott. :thumbsup:
    I would like to get the extras working on it.
    Ill just need to find out exactly where to wire it to
