Dane's Hybrid Conversion Thread
Dane Apr 11, 2011
  1. badger5
    9,370
    1,914
    cost predominantly morgan.. although timescale is a factor currently
    I must admit I forgot about TSR one when I posted earlier.. the confidence comment is not appropriate for that one, it looks as good as you can get a fabricated one.
    TSR looks quality from the pictures
    only technical question I have on it is its bore size & longer runners vs spool... From the pictures it looks like 1.5" sch pipe. Is this the size ?
    PS. hope you are feeling better
  2. badger5
    9,370
    1,914
    that log looks ok...
    not a "fill" question, just a cost one then...
    I know the work involved and its not tsr cahing in, its that labour intensive to make something like that as well as that. (whoever fabs it for tsr will be putting in many hours to make one) - its the design which makes it that labour intensive & costly.. which is why I am attempting to make a simpler version.. less parts, less welding, but hopefully functional. We will see of course. might all go tits up yet - lol
  3. Morgan-VAGCHECK
    Morgan-VAGCHECK Foot to the floor
    103
    Hi Welly,
    If you do find it then it would be most appreciated if you can point me too it, because if this was last year then the logs in theory can only have come from my own TT... & I don't remember posting any ! (That said my memory is ****e)
    I did post a log recently at Bills request here (this does show more lag, but it had a little less pre-load on the actuator than the example above) >
    The Audi TT Forum :: View topic - There is no end to mods.... 297.61BHP ACHIEVED
    Dane sorry for the small highjack, & I wish you all the best with your own hybrid build.
    Regards
    Morgan
  4. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    No worries mate, it's all good info!
  5. Morgan-VAGCHECK
    103
    Hi Bill,
    I am told the runners are 35mm.
    Unfortunately I am still suffering a bit after the op... I just can't sit still & rest to let everything heal (Get bored very quickly!) but thanks for asking :)
    Apologies again to Dane for taking his build thread slightly off topic !
    Regards
    Morgan
  6. Westy
    Westy Well-Known Member
    17,442
    1,100
    Dont worry about it. Dane tends to de-rail everyone elses threads ;)
  7. Dane
    4,086
    182
    :lmfao: Oi! I've been good lately.
  8. slappy_dunbar
    slappy_dunbar Let's Do This
    245
    20
    Morgan --- the spool you are getting on that manifold is excellent. I would put that as the standard to beat for any combination of hybrid turbo / aftermarket manifold. Did you ever log up to and past redline on it? I'd be interested to see when (if?) the boost pressure drops back into the MAP sensor's range.
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Will do. I'll have a look later.
  10. Sandip
    2,438
    91
    Sorry to add to the drifting off topic Dane, here's a log of mine with the JBS manifold, i know they aren't available yet but you never know one day they might be.
    So is the main benefit of a higher flowing manifold so that the k04 can spool up a lot quicker??
  11. badger5
    9,370
    1,914
    high flow manifolds are there to support the flow.... and sustain it not choke it like oe one does.
    whether it spools faster? hmm dont know.
    Picture of TSR's mani for ref..
    fitted
    Mine is looking nothing like this - lol for good or bad
  12. Morgan-VAGCHECK
    103
    Hi Slappy,
    Thanks for the comments.
    Spool is certainly not any real issue as you note.. however I am experiencing some very light surging. It’s not so bad pressure starts to fluctuate, but certainly flow can be a little unstable at lower rpm’s when stepping on the gas unless I limit the pressure to a level I find well... unexciting
    My own (hard) rev limiter is currently set at only 7100rpm although I will be raising this, so I have no logs higher than this currently.
    Below is an example from the same days testing nearly touching the rev limiter with actual pressure on top measured at ~1.65 bar on my external logger. (There was less pre-load on the actuator to the log above, but a little more N75 DC allowed)
    If anyone is wondering about the very high IAT's, these logs were more from an initial "endurance & is it going to work" mani testing session on TSR's dyno hence some long pulls at full load... IAT's do not get as hot as this in real world conditions.
    Regards
    Morgan
  13. badger5
    9,370
    1,914
    you done much more on it since november last year?
    how would you sum it up if complete?
  14. slappy_dunbar
    245
    20
    Freaking sensational. Never mind the IATs -- you're running nearly 30secs continuously on a dyno. I love the power delivery you're getting, especially if you factor in the quicker spool illustrated above. Wow.
  15. badger5
    9,370
    1,914
    maybe 2283 based units are'nt all that bad eh doug? ;)
  16. Morgan-VAGCHECK
    103
    Hi Bill,
    Mapping wise very little has been done.. mainly due to it taking a back seat to customers vehicles, but also plenty of little unrelated hardware issues to be resolved.. fix one thing & in a matter of days I find something else needing attention..
    Leaking core in a few months old Forge FMIC... coolant leak on OE oil cooler jacket, fuel pump headaches, trip to bodyshop thanks to some idiot etc
    The only real progress with the mapping is it is now calibrated for & using a 3bar MAP sensor, so I can keep boost control fully closed loop.
    If I had to sum it up... its been a royal pain in the ass !
    I would like to think "hopefully" & assuming no more bad luck, it will all be finalised around late June.. bearing in mind I can't currently work/drive/make any progress due to the op.
    Regards
    Morgan
  17. Welly
    10,696
    127
    That sounds useful - planning on running N75 control?
  18. Dane
    4,086
    182
    I'm going to pop over tonight if thats alright Bill?
    Also any word from Milltek?
  19. Speedy Steve
    Speedy Steve Active Member
    1,258
    we need teaser photos of the manifold. Dont let us down Dane!
  20. Morgan-VAGCHECK
    103
    Hi Welly,
    My boost has always been controlled via the N75 with this hybrid... however previously in an "open loop" type manner.
    Regards
    Morgan
  21. Dane
    4,086
    182
  22. Dane
    4,086
    182
    ps make sure your heat wrap goes around your Forge charge pipe kids
    melty melty
  23. Westy
    17,442
    1,100
    Oh deah. I did notice you weren't running the heat wrap when I saw your car at Bills!
    Oh what's going on with the game of hangman in your signature? ;)
  24. Dane
    4,086
    182
    I think I ripped it, and now it won't stay in place :ermm:
    My Sig is getting a letter every day until it says Badger 5 edition or I get my car back lol, It's a count down of sorts.
  25. Welly
    10,696
    127
    Bloody hell. I didn't have heat wrap around mine and it came off fine.... Weird?
  26. Dane
    4,086
    182
    It came off easy enough, it had just melted around the lip on the charge pipe over the mani, I haven't been driving it that hard... honest :ninja:
  27. Welly
    10,696
    127
    What's that smell?? No, it's not burning Nomex, it's bull ****....
  28. Westy
    17,442
    1,100
    No doubt it happened when I drove it! :whistle2:
  29. Dane
    4,086
    182
    There we go, thats the reason, Westle broke something else on my car! Thrashing it around the roundabouts - me clinging on for dear life :)
  30. Westy
    17,442
    1,100
    I cant remember what the first thing was I broke?
    I treated your car like a fine woman. I was soft and gentle and caressed her through the bends.
    :racer:
  31. Welly
    10,696
    127
    That's not how I like to treat fine women.... :think:
  32. Westy
    17,442
    1,100
    Ok ok, I was hard and rough and slapped her about.
  33. Welly
    10,696
    127
    Excellent, a good old pull on the hair normally goes down well too...
  34. Dane
    4,086
    182
    :lmfao:
    he slapped me about and all! :slapped:
    I can't remember what the first thing was(n't)
  35. Dane
    4,086
    182
    :lmfao:
  36. Dane
    4,086
    182
    I appear to have de-railed my own thread lol
  37. Westy
    17,442
    1,100
    :haha:
  38. badger5
    9,370
    1,914
    just run out of argon dammit
  39. Dane
    4,086
    182
  40. badger5
    9,370
    1,914
    back with new bottle, on contract with air-products now. smaller bottle, higher pressure built in regulator.. bought another flow gauge also now so I will have full control of purge.. I have to say tho this mani is a proper PIA to make
