Damped Flywheel
purple8 Oct 17, 2012
  1. purple8
    purple8 Member
    67
    Just in process of replacing clutch on a 1.9tdi asv. It has a damped clutch. NEver seen one of these. You can turn the damped part slightly before the flyhweel engages . Is this right. There is a slight bit of play when passed. Again is this normal or do I need a new flywheel.
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Small amounts of play in the flywheel on a dual mass flywheel is normal, if it moves a lot then replace would be my advice.
    It's normally hot spots that are the thing to look out for.
  3. purple8
    purple8 Member
    67
    Thanks. It's damped flywheel not dual mass does that make much did. the clutch looks ok. It wasnt dis engaging. But hydraulic all seemed ok. It actually turns very slightly before engaging to fully.
  4. Welly
    10,696
    130
  5. purple8
    purple8 Member
    67
  6. purple8
    purple8 Member
    67
  7. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
  8. purple8
    purple8 Member
    67
    Follow the link the ASV has a damped flywheel kit its just catalogued i the same section by luk
  9. purple8
    purple8 Member
    67
