Damp/Leak into Drivers footwell, Help Needed!!!!
Diesel Quattro Jan 31, 2013
  1. Diesel Quattro
    Diesel Quattro Member
    118
    Help Needed please,
    my footwell is adamo and its not from wet feet going in and out.
    i am not sure where to start??
    any common problems people know of??
    would something as simple as the vin number plastic breaking, would the water go down there i.e. have a path to get to the footwell??
    thanking you
    aaron
    2001 a3 tdi Quattro
  2. danger S3
    danger S3 Member
    362
    if the black scuttle panel that has the window in it for the vin number doesnt clip into the bottom of the windscreen properly on the passenger side then the water can go in there and down through the pollen filter and into the passenger footwell
    Ali
  3. Diesel Quattro
    118
    Hmm, thankyou. well this is the Drivers footwell and i have no idea where to start looking??
    do the heater matrixs leak?? anyone got any experinence of their driver footwell??
    any help would be appreciated
    aaron
  4. Grale1
    Grale1 Active Member
    795
    44
    Hi did you manage to find where yours was leaking from? I have a wet drivers footwell also
  5. Pubemammal
    Pubemammal Active Member
    525
    117
    43
    Hmm me too!? Has it got something to do with drivers side lower corner of windscreen not fitting properly allowing rain water to leak in behind the dash and into the foot well?
  6. rustynlc
    rustynlc Member
    186
    20
    I have this problem, I'm thinking its getting in via a grommet/bung somewhere along the scuttle panel, ill be looking for the source of the leak this weekend! Been dry in the drivers footwell all week, started hammering down today and the wet patch appears! Definitely rain water!
    Pubemammal likes this.
  7. Pubemammal
    525
    117
    43
    Let me know how you get on :)
  8. S321BAM
    S321BAM I lost the rod lottery
    124
    24
    I had this problem a while ago. Ended up being a missing gromet from previous owners stereo install on the scuttle panel by the passenger side inner arch
  9. jay1601
    jay1601 Well-Known Member
    1,315
    57
    i had a wet driver side footwell, mine turned out to be the grommet where the bonnet release cable runs though had split letting water run in.
  10. JimS3
    JimS3 Active Member
    736
    72
    Bonnet release cable grommet is common, also the black plastic cover in the plenum chamber under scuttle often leaks, especially if aftermarket cruise control has been fitted, they rarely seem to seal properly after being disturbed.
    Sunroof drains and drains in the bottom of the door also worth checking.
  11. lsukltd
    lsukltd New Member
    Oh Gosh I've experienced same issue, I am not mechanical minded at all and would need some recommendations to reliable garage. My Drivers Foot well is soaking when raining. I am in SW London someone who knows what they are doing.
  12. JudderMan
    JudderMan Well-Known Member
    1,004
    164
    The drains at the bottom of the doors? Can you elaborate? If they are blocked, how do you unblock them (successfully)? Or is it just a case of keep on checking and unblocking? I'm assuming my doors are the blame as they are rusty and I have a damp drivers' footwell. The OSR door is the same but no damp in the back.
