Dad decided to remove his fuses with battery still connected, now will not start...
chris.vincent3 Mar 19, 2013
  1. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    He decided to remove his fuses because his DIS went off, and wouldn't turn back on.. Now the DIS is back, his car will not start. It is a DSG and the P is flashing and will not allow him to move the stick.
    Scanned with VCDS and...
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Monday,18,March,2013,23:46:49:02444
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 62 72
    76 7D
    VIN: WAUZZZ8P56A150995 Mileage: 171310km/106447miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC 0000AG 7000
    Revision: 12345678 Serial number: AUX7Z0F0FNN05N
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 78F9ADF70BDAC7D819C
    3 Faults Found:
    19463 - Camshaft Position Sensor (G40)
    P3007 - 000 - No Signal - Intermittent
    Freeze Frame:
    RPM: 1554 /min
    Torque: 68.0 Nm
    Speed: 23.0 km/h
    Load: 35.3 %
    Voltage: 14.06 V
    Bin. Bits: 11000100
    Idle Stabilization: 0.0°KW
    (no units): 48.0
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 136.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 00000100
    Bin. Bits: 00000000
    (no units): 0.0
    18034 - Powertrain Data Bus
    P1626 - 000 - Missing Message from TCU
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00000100
    Bin. Bits: 00000000
    Bin. Bits: 10000100
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans
    Cannot be reached
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
    Component: ESP FRONT MK60 0102
    Revision: 00H13001
    Coding: 0023170
    VCID: 71EF90D368A09690DE2
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    003 - Mechanical Failure - Intermittent
    01315 - Transmission Control Module
    004 - No Signal/Communication
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
    Component: KlimavollautomatH17 0260
    Revision: 274553 Serial number: 8P0820043M
    VCID: 366563CF414EF1A8CB0
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 146
    Mileage: 171318 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 00:00:29
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005407444
    Coding: 118A4F01B214100000160000160000000008FE175A0500
    Shop #: WSC 06314 000 08192
    VCID: 40890517138A4F1861C
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    2 Faults Found:
    00924 - Relay for Headlamp Cleaning System (J39)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 186
    Mileage: 171318 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 00:10:00
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 171318 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 00:15:00
    Freeze Frame:
    ON
    Voltage: 11.95 V
    ON
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H12 3760
    Revision: 91H12376 Serial number: 003620065SNU
    Coding: 0071612
    VCID: 428D0F1F1D865D08778
    No fault code found.
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0011112
    VCID: 418F0013188046106E2
    Part No: XXXXXXXXXXX
    Component: E0221 H03 0080
    1 Fault Found:
    00002 - Transmission Control Unit
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 2240FD06009869
    Coding: 0000413
    Shop #: WSC 00011 888 96745
    VCID: 377B6ECB464408A0D06
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 165420 km
    Time Indication: 0
    Date: 2012.10.19
    Time: 07:10:36
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 300010611989EA
    Coding: 7F3F0F4A07002103
    VCID: 2B5342BB8A0CBC40A4E
    2 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 36
    Reset counter: 186
    Mileage: 171074 km
    Time Indication: 0
    Date: 2013.03.10
    Time: 19:35:32
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 16
    Reset counter: 186
    Mileage: 171318 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 00:00:28
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0F0FNN05N
    Shop #: WSC 00000 000 00000
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 346159C75732E3B8F54
    1 Fault Found:
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 188000186D088505489FC63300
    Shop #: WSC 00583 210 64856
    VCID: 3C7171E77F622BF83D4
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    2 Faults Found:
    01320 - Control Module for Climatronic (J255)
    00352 - Terminal 30A
    011 - Open Circuit - Intermittent
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674548345674
    VCID: F1EF10D3E8A016905E2
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000012
    VCID: 3D777CE3647822F00AA
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H52 0100
    Revision: 02S Serial number: AUZ2Z3F3497800
    Coding: 0001011
    Shop #: WSC 06435 000 00000
    VCID: 326D5FDFAD26ED88E78
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 17
    Reset counter: 186
    Mileage: 171081 km
    Time Indication: 0
    Date: 2013.03.10
    Time: 19:53:05
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0020
    Revision: 00H09000 Serial number: 00067824820601
    Coding: 0001113
    Shop #: WSC 131071 1023 2097151
    VCID: 397F68F370501ED0262
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D574CA3B418B270BAA
    End ---------------------------------------------------------------------
    Deleted the faults then.. Atleast some went away.. :/
    Monday,18,March,2013,23:50:27:02444
    Chassis Type: 1K0
    76 7D
    Coding: 0000078
    1 Fault Found:
    Freeze Frame:
    RPM: 0 /min
    Torque: 88.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.55 V
    Bin. Bits: 00000100
    Bin. Bits: 00000000
    Bin. Bits: 10000100
    Readiness: 0 0 1 1 1
    Cannot be reached
    Revision: 00H13001
    Coding: 0023170
    1 Fault Found:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 146
    Mileage: 171318 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 00:00:29
    Freeze Frame:
    Coding: 00062736
    Shop #: WSC 06314
    Coding: 0071612
    Coding: 0011112
    Coding: 0000413
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 165420 km
    Time Indication: 0
    Date: 2012.10.19
    Time: 07:10:36
    Cannot be reached
    Coding: 0000688
    1 Fault Found:
    000 - -
    Coding: 0000688
    Coding: 0000012
    Coding: 0001011
    Coding: 0000144
    Coding: 0000144
    Coding: 0001113
    Where the bleeding hell do I start..
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Have you tried a battery reset and checked all fuses. Then id try clearing the faults and a drive cycle, why did he pull fuses anyway?
  3. chris.vincent3
    604
    34
    he said he's tried unplugging the battery and its still stuck in park. Yeah fuses all look fine. Because he thought he would check the fuse for the dash as his DIS wasn't working, why he felt the need to remove all of them is beyond me..
  4. bmh.01
    bmh.01 Member
    291
    17
    He's either put one back in the wrong place or blown another. Looks like its lost the drivetrain can network.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Should be noted of it was not only his dis working the car wouldn't start as i believe the immo is in the instrument cluster
  6. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    I'd check all the fuses again and make sure they are in the right places.
  7. chris.vincent3
    604
    34
    i had a look last night and he's missing one for the auto trans, put one in obviously the right amp and still nothing. I'll have another look when I get in, but it's hard to know what he's missing as I haven't seen it before he was let loose in there.
  8. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Chris, what I would do now is to go over the fuseboard with a fine toothed comb, and make double sure that every working circuit has a good fuse. Your dad already missed out one fuse, so there may be others missing too. If you put a fuse in an unused circuit, it should not matter. Don't forget there are two fuseboxes, one under the bonnet, and one inside. When it all checks out OK, then do a battery disconnect, short out the battery connections for a few seconds (electronic reset), and then connect up again. With all circuits now live together, there is a chance it will recover and start communicating properly on the can bus. Good luck.
  9. chris.vincent3
    604
    34
    Thanks for the reply, I was thinking exactly that, filling the whole fuse box with correct fuses even if its not needed, as it won't do any harm if there isn't a circuit there.
    Is there a right/wrong way to short out the battery? I've not heard of doing that before :-/
  10. TDI140
    TDI140 Well-Known Member
    1,624
    174
    Check all fuses and have a look to see if any are blown then get hold of vag com after replacing the blown fuses if any, run a scan and then clear all faults, it should be all ok fingers crossed
  11. Geraldy212
    565
    42
    Chris, when you simply disconnect the battery, it takes off the 12V supply to all of the car. However, some electronic modules may have capacitors installed that might retain some power. So an easy way to discharge any residual voltage is to touch the connections together, so shorting out any residual power to ground. That at least ensures that you restart from a real zero voltage. Anyway, it can do no harm. Just thought of something..... are you sure that the immobiliser is not allowing the car to start? I believe that you need the key fob correctly registered to the car in order to please the immobiliser circuits. I am sure a forum member can confirm this.
  12. chris.vincent3
    604
    34
    Thanks everyone, tried everything you guys suggested and it now runs and drives. Will find out how well tomorrow when he takes it to work.
    A few faults came up after the initial scan but after clearing majority haven't came back, anyone able to give some pointers on how to fix the remaining faults?
    Tuesday,19,March,2013,22:39:26:02444
    Chassis Type: 1K0
    76 7D
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    Coding: 0000078
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 S HW: 02E 927 770 AE
    Component: GSG DSG 070 1102
    Revision: 04507000 Serial number: 00000601190787
    Coding: 0000020
    VCID: 2343AA9BE2DC74001CE
    Revision: 00H13001
    Coding: 0023170
    Coding: 00062736
    Shop #: WSC 06314
    Coding: 0071612
    Coding: 0011112
    Coding: 0000413
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 165420 km
    Time Indication: 0
    Date: 2012.10.19
    Time: 07:10:36
    Cannot be reached
    Coding: 0000688
    Coding: 0000688
    Coding: 0000012
    Coding: 0001011
    Coding: 0000144
    Coding: 0000144
    Coding: 0001113
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    looks a lot like the instrument cluster may be defective, i would try putting the long code back into it. failing this im a bit stuck maybe a new one required. possibly you could get that guy that was flashing the rs3 software onto them to give that a shot see if it sorts it out
