DAB retrofit
Cozza McA Dec 2, 2012
  1. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    iirc that doesn't work with rnse
    looks simple enough but ive always found dab in a car to be patchy where i live
  3. Cozza McA
    410
    73
    ah well im ok there then only the concert system in my car.
    Currently i have two normal channels to chose from.
    DAB in my area is pretty good
  4. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    We sell exactly the same on our site:
    Audi DAB Aftermarket AutoDAB Radio A1 A3 A4 TT | Advanced In Car Technologies
    We were told by the manufacturer that it will work with the RNS-e.
    It won't however show any Radio / Track / Title info like you would get on a normal DAB radio. It is all controlled through a MFSW (You must have a MFSW!) and your DIS.
    It is a really cool product!
  5. andykn
    andykn Member
    159
    You chopped the 'r' off the end of the your link:
    Does look like an interesting piece of kit, wish it had been around three years ago when I was putting DAB into my A3. I ended up with a Bluestate RA-558 DAB and Bluetooth aftermarket radio.
  6. Cruiser89
    1,484
    221
    Sugar.....
    Cheers bud! Yes it's a pretty good kit for the money. Especially with FM due to switch off around 2015.
  7. Cozza McA
    410
    73
    I was thinking of installing this at the same time as a muti function wheel.
    Would it still work with a retrofitted wheel?
  8. mike foster
    3,967
    It won't matter whether the wheel is retro-fitted or not, just the fact that it works !
    However, you need to be aware that you need the correct steering module for the wheel to work at all ( apart from just steering that is !!!!! )
  9. Sidhu88
    Sidhu88 Active Member
    808
    76
    Its not exactly a DAB retrofit if its an aftermarket part. I've installed these on cars before and they're really good. As mentioned before it only works via steering wheel controls. Get urself a bunch of cable ties or some velcro and mount the unit somewhere tho. With the amount of space behind the a3 dash it'll easily slide around or bounce about which will be very annoying after a while.
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    cruiser, ive been looking into a rns 510 for my daily golf amungst all of the reading i keep seeing romours of a 510 with DAB is there any fruit to these?
    if you can supply one or any info on one please drop me a pm, id rather not fit an aftermarket interface to the rns if i dont have to
  11. Cruiser89
    1,484
    221
    The rumours are true...
    Can't say any more at the mo but they will be coming at some point in the near future :) It's going to be a game changer in the VW world!
    We'll be announcing it on our Facebook page as we may run a competition around it. But will definitely let you know via PM!! Could maybe sort you out with the first one :)
    Tim
    http://www.facebook.com/AdvancedInCar
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    more than happy to wait for it, i live in scotland so id be interesed in supply only for my convenience but i have full access to vagcom and autologic so i can do everything except the germany connect. ill await you pm but if you can give me a rough cost at least id know what id have to lay aside :)
