D.V removal.HELP
nell.l May 21, 2011
  1. nell.l
    nell.l New Member
    21
    Tried to fit a new dv to my 2.0tfsi quattro.there is just no access,I had the car up on a ramp an still i just could't get to it enough. any ideas?
  2. BigBird
    BigBird Lost in music...
    382
    I thought it's right up on top - certainly my replacement one on my 2007 S3 is easily reachable between the engine block & battery / CAI area and the original one that's cable tied out of the way is right next to it & easily accessible.
    Maybe it's moved on newer cars, but mine wouldn't need a ramp to change it fella...
  3. Boydie
    Boydie Boycie VCDS Map User
    3,293
    397
    The 2.0tfsi from the Gti is at the bottom and as far as I am lead to believe it is a ******** to replace
  4. BigBird
    382
    Nightmare! Sorry OP - just for once the S3 is easier to tinker with than other models.
    I'll get me coat. Again...
  5. antmax7
    antmax7 Member
    295
    jack car up from drivers side remove drivers wheel if you need to go from underneth car unclip electrical plug use a torks socket a universal joint and a extension bar there is only 3 bolts shold take no more that 30-40mins from start to finish
    HTH!
  6. nell.l
    nell.l New Member
    21
    THANKS FOR THE HELP. I think i'll have another go an as you say remove the wheel an maybe some off the plastic trim and see if an extension will do the trick.
  7. RobinA3
    RobinA3 Well-Known Member
    1,826
    45
    As Antmax7 mentioned you can do it by removing the driver side wheel, you don't need to take any plastic guards off. You really need a 1/4'' rachet with some extensions on it with a swivelley (sp) on the end.
    All 3 bolts can be accessed without too much issues, i did mine a couple of months ago on the driveway, took about 20mins in total. If you are close to me then i am more than willing to give you a hand doing it.
  8. nell.l
    nell.l New Member
    21
    NEW dv working a treat.
    Thanks for the advice people.
