Cylinder order.
manxman Oct 29, 2005
  1. manxman
    manxman New Member
    14
    Hi, Just a quick one, VAG Com is showing misfire on cylinder 2. Coilpacks?!
    Are they 1-4 left to right standing in front of the engine?
    Thanks!
    Chris.
  2. PaulRS3
    PaulRS3 Well-Known Member
    1,203
    138
    no idea
    id swap the fisrt two coil packs around , working from the left and see if fault moves.
    as cyl 3 and 4 working Left to Right involve more work to get at.
    if it moves, you found fault.
    if it doesnt, you have either...
    got wrong one.
    got problem with wiring to coil pack
    or
    got a problem with a spark plug.
  3. RichA3Turbo
    5,089
    Cylinder 1 is drivers side, 4 is passenger side.
    Rich
  4. manxman
    manxman New Member
    14
    thanks! /ubbthreads/images/graemlins/groovy.gif
  5. manxman
    manxman New Member
    14
    Looks like its a dodgy coil pack. The only one in the car thats original and not J lasted to 47k though. /ubbthreads/images/graemlins/grin.gif
  6. nickel101
    nickel101 Member
    97
    oh no....
    sounds like a problem i had. My cyclinder 3 was misfiring which turned out to be that the cyclinder was way under pressure...
    er go i got had to get new valve for it, new gasket, new cambelt /ubbthreads/images/graemlins/frown.gif
    mucho moolah
  7. manxman
    manxman New Member
    14
    finally managed to get a coil pack and its all sorted /ubbthreads/images/graemlins/smile.gif
