cylinder 1 misfire error and poor running
nky_84 Apr 7, 2014
  1. nky_84
    nky_84 6th Gear
    472
    13
    Hi guys,
    I removed my injectors the other day to temporarily fit them in another car, which it turned out they werent needed. When i was removing them, some / all of the fuel rail petrol dripped into one of the cylinders (furthest left if standing in front of the car). All happened quite quickly to do anything about but thought it would just evaporate or burn off...
    A day later, i refitted the injectors and the car spluttered to a start but was fine once the fuel rail had filled up with fuel again. I drove very gently for about a mile or so until a hill forced me to use a bit of power. When the boost came in a bit stronger, about 2700rpm, it started to splutter and misfire :-(.
    I crawled back the house when the engine warning light came on and then started to flash (only under power). So i plugged in one of those cheapy fault code readers and it came up with cylinder 1 misfire code.
    Ive changed the plugs
    swapped round injectors
    i'm about to do a compression test to confirm/deny the worst!
    I'm guessing ive upset a sensor rather than done anything serious but if anyone has any suggestions on what to try next im all ears!!
    Cheers,
    Nick
  2. Lewis583
    956
    91
    Seeing as you've swapped injector to another cylinder, did the misfire follow?
    Swap the coil pack on cyl 1 with cyl 2/3. Re-scan for faults and see if the misfire fault follows to the new cylinder. If it does coil pack is knackered, if it doesn't then you need to start looking at wiring or anything you disturbed when removing the fuel rail.
  3. nky_84
    nky_84 6th Gear
    472
    13
    Misfire didnt follow when i swapped injectors, but it did when i swapped coil packs. Error code jumped from cylinder 1 to 2!! PHEW!!!
    Are audi still replacing coil packs FOC these days? Its a 2002 51plate S3 BAM.
  4. Lewis583
    956
    91
    Not sure to be honest fella. Give them a call, worst they can say is no. To which you buy some cheaper aftermarket coils. :happy:
  5. Mrt4x4
    Mrt4x4 Member
    59
    Yea i had my coils done only 3-4 weeks ago at audi leeds
  6. nky_84
    nky_84 6th Gear
    472
    13
    yes, the car is covered for FOC replacment, but ive got to get it 20miles to the nearest audi dealers on 3 cylinders.....
  7. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    I had to drive mine around 15/20 miles to get mine replaced tbh.....just take it easy
  8. Mrt4x4
    Mrt4x4 Member
    59
    See if you can get hold/borrow a coil to get you there, luckily for me i was able to get the aa to pop me one in temporarily
