CVT problem please help! A4 1.8T (190) SLINE
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by Jonahjones26, May 2, 2013.
  1. Jonahjones26
    Jonahjones26 Member
    Feb 18, 2013
    61
    I have a problem with the cvt box , my garage say its the torque converter (which i believe is the cluch in an auto????)
    basically when i pull off it does a judder very slight and occasionally in other gears............
    anyway i need a specialist in the midlands to have a look and do the works please help :(
    also what sort of price am i looking at?
    thank you a very sad audi owner!
  2. Advert Guest Advertisement
  3. madmike01uk
    madmike01uk Member
    Mar 7, 2013
    430
    21
    Not in the midlands, but I've saved these as a seller on ebay in case I have any issues with my CVT, they came recommended on here tadeusz1978 | eBay
    Might be worth calling them and talking them through your issues, they might be able to advise what the fault is. It sounds like a clutch issue, has your car had the 6 to 7 plate upgrade?
    Mike
  4. Jonahjones26
    Jonahjones26 Member
    Feb 18, 2013
    61
    i dont know tbh, no documents to say it has?
    can the 6 to 7 be done on a petrol as i have been ringing around for quotes and one specialist said it cannot be done on the petrol 1.8t (190) is this correct?
    thanks i will give them a ring and see.
  5. Jonahjones26
    Jonahjones26 Member
    Feb 18, 2013
    61
    I now have the car in a garage the first thing they are doing is changing the tensioner pulley ... Which they say is a common issue
    but they say that this will still not stop the judder issue and have quoted me £1600 to supply and fit the 7 clutch pack, software update and gear box fluid. They said the parts alone are £955? Is this correct as a garage further a field say they can do it £1140? Which sounds great but its miles away I have to trains back a forth plus the petrol but if it saves money?
    I still can't afford it right now so any specialist / prices would be very helpful. Thanks.
  6. madmike01uk
    madmike01uk Member
    Mar 7, 2013
    430
    21
    That place I liked to claim to do it for £550 all in.
  7. Jonahjones26
    Jonahjones26 Member
    Feb 18, 2013
    61
    Yeah he is some guy doing it out of his garage, who is refurbing the plates not changing it to a 7 clutch plate. And the 6 month gaurentee is basically his word? He could probably do it perfectly well but I am not going to risk it !
