CV joint clunk
tdi-man Aug 23, 2009
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    having noticed a clunk noise when going round corners (cv joint)some times and have noticed i get it when i put my foot down in a staright line /
    any ideas cud this be drive shaft aswell or just cv joint ?
    also how do i check timing on vag com 704.1
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,488
    633
    Jack the car up and give the area a good shake - check the drop links for wear and tear
    Give everything a good tightening incase anything is loose - have you changed suspension at all??
  3. Lee_R
    Lee_R Active Member
    2,499
    12
    Probably just the CV, the driveshafts are not know for causing issues
  4. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    If it's repetitive/cyclic 'clack-clack-clack', it may be a CV joint, but if it's a one-time "knock" then it's probably more likely to be the something like the upper strut mount...
    Certainly, that's fairly common on FWD VW platforms, -My A3 is too young to do it just yet, but every other FWD VW I've ever owned has done it as the miles stack up.
    Keith
  5. tdi-man
    1,783
    64
    hi yer its a clack clack clack noise any body know how to get the drive shaft part nymber for car ?
  6. tdi-man
    1,783
    64
    changed drivers side drive shaft today but still getting a clunk when turning right round rounabouts.....any ideas ???????
  7. tdi-man
    1,783
    64
    cpassenger side shaft changed today and no clunking when going round roundabouts and no clunk on excelleration......
  8. ned.c
    ned.c Member
    33
    Hi tdi-man, getting the same click click click symptoms on mine with some lock on and already suspect nearside outer CV joint due to noise and also noticed one of the cv boot clips is missing when I did an oil change last night, where did you source the joint and how much was it if you don't mind me asking?
    cheers,
    Andrew.
  9. tdi-man
    1,783
    64
    hi i put 2 complete shafts on m8 due to high milage..genuine audi
